ZDriver.com
-   Other Cars (https://www.zdriver.com/forums/other-cars-223/)
-   -   1969 Datsun 510 2Dr Z22 turbo EFI build (https://www.zdriver.com/forums/other-cars-223/1969-datsun-510-2dr-z22-turbo-efi-build-36313/)
FricFrac Oct 12, 2012 09:54 PM
4 Attachment(s)
Well I guess I should start a build thread. Like everyone and their dog here long time 510 fan always wanted one but being a Z car guy first and foremost the 510 kinda went to the back burner. Kept an eye out and missed a few but most of the stuff around here is rotten and goes for a fortune. Long story short a guy I knew had one about three years ago. It was a project he picked up from a kid. Put the car back together, added bubble flairs and painted it flat black. Found a rebuilt L16 and dropped it in. Shortly thereafter he found his dream car - '60's Impala which he proceeded to dump huge piles of cash into to build his dream car. I told him if he was ever going to sell the 510 to let me know. Three years later I get a message on my phone from our local classified adds which pops up any time anything Datsun is listed. 95% of the time it's either wheels that fit a Datsun, books with Datsun in a picture on the 59th page or some rotten piece of junk. Anyhow this time it turns out to be this 510 and it sure looked like the guy's car that I talked to years ago so I call the number right away. He answers the phone and I ask him if this is so and so and it turns out it's the guy. He says he just posted the ad less than five minutes ago. Anyhow I ended up buying it and so it begins....
After she arrives at home with some of her stable mates:
Attachment 17197
Missing the rear cover so I covered her shame with a piece of sheet metal till I can get around to fitting something properly.
Attachment 17198
FricFrac Oct 12, 2012 10:03 PM
10 Attachment(s)
Of course I haven't even had her towed home and I'm researching engine swaps. You know the usual KA24, SR20, VG30E and ET, etc... I'm trying to get 'er running in the drive way and I'm not having a lot of luck. I rebuilt the carb not knowing what kind of shape it's in. Getting better. Find a bunch of vacuum leaks. Replace the weak coil. I'm an Electronics Eng so I pull the stock harness out of the engine bay and give 'er a rebuild. I've got all the connectors for the 240Z, etc so I was already good to go there - add some new ground wires, etc. The whole time I'm fighting with this I'm thinking how much easier it would be if I was running Mega Squirt like I just built for the 280ZXT. That's when I start thinking about building an L16 turbo with EFI (MS3). I start researching about how to make this happen. I think it would be a fun little engine and I don't need an insane build - I've got other cars that make lots of power and the L16 turbo is kinda unique as most people don't bother. I start researching EFI manifolds and figure I'm going to have to build my own. Then I start trying to figure out how I'm going to trigger the EFI. Looking into an L28ET dizzy, etc and I find out that the Z24i has an optical dizzy. It also has a hemi head with a good quench area - hmmm that's perfect for a turbo build. A friend of mine tells me he has a Z22 so I do some horse trading (thanks Greg!) and now I'm going down the Z22 EFI turbo road. She burns oil so now's the time for a rebuild. The tentative plans are a full gasket set, ITM hyperutectic pistons and rings (only $50 more than rings alone - seems like a no brainer), ARP head and rod bolts (good for a boosted engine and the NAPSZ seems to have an issue with the head bolts getting loose after time), and Cleavite crank and rod bearings. Once we get her cracked open we'll see if anything else needs doing but I'm trying to keep this fairly low cost. I picked up an extra oil pan (thanks Peter!) and oil pickup (thanks Hayden!) so I don't need to rip the L16 apart to build this thing.
So the challenge of this beast is to get it into EFI land. I'm already part way there researching for the L16 EFI conversion. I need an EFI manifold from an early 200SX (Z20) and an optical dizzy from the later Z24i Hardbody. DatsunMike as always has been a pile of help. Posted tons of picks and pointed me in the right direction. Found a dizzy from a Z24i (thanks Sealick!) and while I was looking at a 280ZX for a good friend of mine I look down in the dirt literally and there lies a 200SX intake plenum and runners - the last piece of the puzzle (thanks Robert!)
So here's the plenum and runners before the masaging begins (minus 12lbs of pine needles)
Attachment 17187
Attachment 17188
Intake runners bead blasted, ported and polished
Attachment 17189
Attachment 17190
Intake plenum ported to accept a 240SX 60mm throttle body. Might be a little overkill so I may have to go to a 280ZX 48mm TB for better throttle response. We'll have to see how it works out.
Attachment 17191
Intake plenum with 240SX TB and an adapter plate made of 1/2" aluminum. Two screw holes are tapped into the plate to mount the TB and the other two line up with the stock mounts. Third set of holes mounts to the stock location below the TB. Cut the water inlet/outlet off the TB to reduce plumbing.
Attachment 17192
Attachment 17193
Attachment 17194
Plenum and TB test fitted. TB adapter is port matched to the plenum
Attachment 17195
Attachment 17196
FricFrac Oct 12, 2012 10:36 PM
3 Attachment(s)
And here's my dizzy from a Z24i with the optical encoder wheel. I might be able to use the wheel as is since it has a larger slot for TDC. MS3 firmware 1.1.2 supports the Nissan CAS so we'll see if that works. If not I've got a 24-1-1 50mm optical encoder wheel we cut on the water jet that should work instead. I cut it for the L28ET but it's the same size conveniently ;)
Has the same 10 spline count as the L28ET oil pump shaft which should work in the Z22
Attachment 17184
Stock 50mm optical encoder wheel. Same size as the L28ET and VG30E dizzy. Different in that it has a larger slot for TDC whereas the L28ET are all equal size (and six instead of four slots on the second ring)
Attachment 17185
The pigtail looks like it goes right into the dizzy but it's just a cover plate that holds the more common rectangular four pin connector - same as the L28ET dizzy. Nice as this makes it easier to interface to
Attachment 17186
ThaPimpShrimp Oct 12, 2012 10:43 PM
Looking good so far! I am excited to see how this turns out because I am a big 510 fan also. There are so many of them in my area for cheap I am very tempted to pick one up... but I have to refrain!
Good luck with the build FricFrac! I'll be following it closely :D
FricFrac Oct 12, 2012 11:39 PM
Cheap 510's? - buy them all!
SHADY280 Oct 13, 2012 08:13 AM
nice build fricfrac, when i had my 620 i was gonna do this and i had a 219 sss head for it as well. a guy bought it from me before i even had a chance to play.
NismoPick Oct 13, 2012 08:20 PM
w0w! You have too much free time on your hands. :D
I lolol'd at this local 510 ad:
$1k for a smokin wild / popular 510? er nope... just compiling all the cool pics on the intrawebs... this 510 is trashed.
FricFrac Oct 13, 2012 08:48 PM
Lol it's mostly lunch break stuff
Mishimoto Oct 15, 2012 10:21 AM
Very neat build! Subscribed.
FricFrac Oct 16, 2012 05:47 AM
...and I just cleared out my storage locked and put my Star Trek : The Next Generation pinball in the house which doesn't work. Another project but "what player can resist balls being launched into space at warp speed?"
FricFrac Oct 19, 2012 09:00 PM
4 Attachment(s)
Took the engine apart so it's all sitting in bits on my buddy's garage on the bench. Took the head apart and started to give 'er some loving:
The gratuitous before picture of the carbon coated chamber:
Attachment 17178
After a good long cleaning:
Attachment 17179
After I cleaned the combustion chamber I saw quite a bit of damage. Looks like something bounced around in all the chambers. Of course the first one I started working on was the worst and I forgot to take before pictures but you get the idea from this one:
Attachment 17180
After some sweet loving she's starting to clean up. Still in the process of cleaning the chamber up but it looks like there is hope :) Tried to remove as little as possible but I'm not too worried about reducing the compression ratio from the small amount of material removed. Just trying to keep the chamber as clean and slick as possible to keep any hot spots to a minimum and thus prevent detonation. It will of course help with flow but reducing detonation is more important IMHO in this turbo application.
Attachment 17181
Mishimoto Oct 22, 2012 07:17 AM
Wow that head cleaned up very well. What kind of process/products did you use?
FricFrac Oct 22, 2012 04:00 PM
Taped the poodgies out of it as well as heat shrink around the valve steams then I glass beaded the combustion chamber and outside of the head. Blew everything out and washed with soapy water and a heavy brush - rinse repeat multiple times. There can be glass beads impregnated into the aluminum so you want to be sure to remove them all. I'm polishing the combustion chamber so it's highly unlikely anything will remain even if anything got past the previous cleaning. I hit the valves with the wire wheel as I didn't want the glass beader to hit anything but the face of the valve steam.
Mishimoto Oct 23, 2012 06:32 AM
Awesome good tips here thank you. Good luck with the rest of the project. :icon_super:
FricFrac Oct 26, 2012 08:38 PM
2 Attachment(s)
Sow's Ear:
Attachment 17158
Silk Purse:
Attachment 17159
FricFrac Oct 29, 2012 08:22 PM
1 Attachment(s)
Didn't get a spindle with my Z24i dizzy so I had one "made up" from an L28ET (which is too long) with the optical dizzy (eg not an '81 with the CAS). Sleaved for a nice compression fit. The original stock dizzy spindle beside the modified one.
Attachment 17153
FricFrac Oct 30, 2012 10:59 PM
1 Attachment(s)
Z24i optical dizzy with a modified L28ET oil pump spindle - voila!
Attachment 17152
FricFrac Nov 6, 2012 10:37 PM
3 Attachment(s)
Woohoo! Parts!
ITM hypereutectic pistons, bearings, gasket set, Melling M111 high volume oil pump, chain guides, ARP head and rod bolts, etc
Attachment 17118
Attachment 17119
Attachment 17120
SHADY280 Nov 13, 2012 06:38 AM
nice!! good work on that oil pump shaft.
FricFrac Nov 15, 2012 01:48 PM
4 Attachment(s)
Parts back from powder coating L16b oil pan for the conversion. Valve cover is bright red - for some reason it's bright orange in these pictures
Attachment 17084
Attachment 17085
Attachment 17086
Attachment 17087
FricFrac Nov 26, 2012 02:55 PM
4 Attachment(s)
After spending a few days researching I think I might have a solution to my turbo manifold question - as in what am I going to run for a turbo manifold. Someone mentioned that the KA24E exhaust layout was the same as the NAPS Z head. From what I can tell it looks like it will work but there isn't any way to tell without seeing it up against the head. I don't have access to a manifold and I hate to order parts without knowing for sure but I found one for a good price and if it doesn't work there are a ton of S13 guys around who would probably buy it. The exhaust outlet on the Z22 is oval(ish) whereas the manifold for the KA is round so I'll have to do some port matching one way or another which I would have done anyhow.
The other question since I had the option was log or tubular manifold. After much deliberation I went with the log manifold as it will spool faster because of the lower total volume inside the log manifold. There is also less thermal loss in the log manifold compared to the tubular which also helps spool more quickly. While spooling doesn't give you more power it does give you more power under the curve. The log manifold is top mount and it's offset towards the front of the car which should keep out of the way of the strut towers.
Attachment 17064
Attachment 17065
Attachment 17066
Attachment 17067
FricFrac Dec 3, 2012 09:25 PM
2 Attachment(s)
440cc injectors!
Attachment 17050
Attachment 17051
Mishimoto Dec 4, 2012 06:48 AM
Excellent, everything looks so clean. Excited to see this one on the road. :icon_super:
FricFrac Dec 4, 2012 11:08 PM
Got any advice on a good 510 rad? ;P
Mishimoto Dec 5, 2012 07:15 AM
Sent you a PM. :icon_super:
