Motorsports This board is for Z Racers who compete in Autocross, Road Racing and Time Trials. Focus will be on car set up and modifications. Event coverage, and race parts for sale or trade.
Wilwood Rear discs Like Tom's
Old Oct 3, 2003 | 09:51 AM
Spudz's Avatar
Hey Guys,
Another plan I have for this Winter is to install Wilwood rear disc calipers like Tom did on his car .
Here is the link to it :
http://sth2.com/Z-car/brakes.htm
I have to double check and see if these are going to be legal in E Production . Doug Piner told me his is running Wilwoods on the back of his road race car .
Mike
Old Oct 3, 2003 | 11:10 AM
tholt29's Avatar
I'll make you a helluva deal on those brackets that mount the caliper at the top of the rotor!
Old Oct 3, 2003 | 12:46 PM
Spudz's Avatar
LOL.... I bet you will !!
Now if I can just turn the hub 90 degrees I am set
BTW... where is a good place to buy the Wilwoods at ??
Mike
Old Oct 6, 2003 | 11:11 AM
tholt29's Avatar
I got mine from Speedway Motors... Here's their short link:
http://www.speedwaymotors.com/xq/asp...qx/product.htm
If that doesn't work, just go to their main page and click your way through...
Tom
Old Oct 6, 2003 | 03:41 PM
Spudz's Avatar
Thanks Tom !!
Wow other then the cost to have the bracket made up it won't be that expensive of a swap.
What brake lines did you end up using ?
Did you use any adaptors or run your own lines from the remote resevoir ?
Also what pads are you running with the
set up for autocross ?
Mike
Old Oct 7, 2003 | 07:06 AM
tholt29's Avatar
For brake lines I just ran some short steel lines from the T above the diff out to the frame rails and then ran braided lines to the caliper. Learn from my experience and don't put the braided line directly above the halfshafts... bad things happen there...
My pads are Carbotech Kelated Greens. They stop well, but they squeel like the proverbial pig. I've tried extra shims, brake quiet, and a few other things... They are just annoyingly noisey. I am considering trying the Hawk HP plus to see if they work as well without the noise.
Tom
theatriks
Nov 22, 2013 09:37 AM
znasty1
May 15, 2005 11:06 PM
yellowvx
Aug 20, 2003 07:36 AM
280zx Fever
Aug 8, 2003 01:43 PM
JTZ23
Aug 14, 2002 06:04 PM
