14 Inch Road Slicks
Hey Guys I Need To Find A Set Of 14 Inch Road Slicks For This Year. I Dont Even Care If There 50 Percent Used. Any Places I Can Find Such A Thing. All The Places Up Here Just Look At Me Like Im Crazy And Say They Cant Get Them Or Its Impossible, Even For New. If They Can Find Them There Like 250 A Piece. I Think Thats A Little Much.
14 inch slicks is a real odd size. You can get some very sticky competition compound tires in that size (Kumho, BFG, etc.). If you really want slicks - call Subie Sports in Huntington Beach CA. (714-847-1501) They handle Michelin rally tires - which makes a 14 inch slick - not cheap - but available.
Thats What I Thought, Not Cheap. What Are The "cheaper" Slicks, 15, Or 16, And What Wheels Will Be Affordable To Race With, Pass Tech And Match The "cheaper" Tire
Re: Slicks
If you're looking for used slicks - the place to go is a guy in wisconsin 262-740--0180.
I've purchased a couple sets from him. Hoosiers have been great - Yokohama more accurately described as Rockahama. They last forever but not very sticky. We run 15's - but they have a better selection of 16's. Steel wheels are heavy as hell - but cheap. Look for Diamond wheels in any roadrace magazine. You can order any size and offset you want. Make sure you don't order a combination that will not fit the car! |
Thanks For Info Fpguy, What Class You Race Mostly In, And In That Class Do You Need A Turbo To Compete. Also Do The Doors Have To Open
The car is set up for F Prepared. It's completely stripped down to about 1900 lbs. The doors are just the skins - with cabinet hinges tack welded to the front fenders (saves weight). Of course the handles are also gone so we use hood pins to keep them closed.
They do need to open for safety reasons. A turbo would put us into a different (more expensive) class and I doubt it would make us any faster. Our engine was built for low end torgue - which is what's needed for short/tight autocross courses. |
Would Canada Have Similar Specs To The Usa, So If I Came Down I Could Race, Or Would The Tech Guys Send Me Packing.
I have no idea. You can get the SCCA Solo 2 rules online - just go the the SCCA website.
Compare them to whatever group you race with in Canada. Most groups have similar safety regulations - the only difference might be car classification. As long as the car is safe - they'll find a class that fits the car and you'll be able to run. |
As a comparison I tried to find out what Panasport's C8-16 modular wheels weighed in at, and couldn't find anything. Every site I found didn't have anything listed for the 16's, only the 13's. Panasport's own site doesn't look like it's been updated since 1995. Does anyone know what they weigh? |
My C8 16x12's weigh 17 lbs. on a bathroom scale. I haven't checked them on a good scale.
Cary |
A Start Is All I Need Next To The Car And The Licence :d
Hey Cary,
I'm curious - why are you running 13 inch wheels? Any problems getting them to fit over the brake and lower control arm? |
Any problems getting them to fit over the brake and lower control arm? 13s will not clear stock brakes and you have steering arm clearance issues, bumpsteer spacer issues, etc. It was a corner I painted myself into and if I were to do it again I would still use the FA tires but probably in the 15 inch size. Cary |
i've always played with the idea of running 13 inch wheels to reduce weight - but was concerned about getting them to fit.
We're currently running 15 x 9.5 wheels. Last season we managed to squeeze some 11x15 C-3000 Hoosiers on them. Prior to that we ran 9x15. The 11's called for a wider wheel but they seemed to work OK on the 9.5's. We really like those tires - but not many people use them so they're not easy to find. |
We really like those tires - but not many people use them so they're not easy to find. I chose the FA tires because of how easy it is to get them. One of the people that runs with me is using 16s and goodyear radials. On a hot day his car works well but he has problems getting them to heat up. He is switching this year to 15 inch atlantic tires and already found a couple sets. Cary |
I bought some 15 inch FA slicks from these guys. Their list isn't always current so e-mail or call with what you need. http://home.comcast.net/~gduncan2/GT...TiresInfo.html
I think you are still limited to 12 inch wide in F Prepared but unlimited in X Prepared. |
Thanks
Hey thanks for the tire source.
We'll give them a call |
