Where can I get a diffuser?
Arrrgh! I've been searching the net for hours, and still can't find a skylight diffuser (mine is broken). :armata_PDT_35: Lowe's, Home Depot, Ace and other hardware stores around here said they don't carry them. It's just a textured piece of clear plastic (similar to a florescent light fixture cover) that mounts slightly recessed on my ceiling. I looked up "skylight cover", but only found covers that mount on the exterior of the house, so that's not what I need.
Does anyone know where I can get one? :022: |
why do you want to block your skylight? whats the purpose of getting one installed then? i have a skylight in my B'room lol...
Well you can look for ...crap what is it? I think they are called drop cealings or suspended cealings or something...my friend and I put up panels in his kitchen and they were textured...I don't know how big your skylight is but we had to cut down these pieces...and we got them from the Home Depot. I think after we cut them they were 18 x 32 or something close to that...I hope that helps you a little.
You can make a custom diffuser that drops in the middle, use some 1/4 dowels and make a frame then bring some dowels down to the center of the light and just put 4 triangular pieces of textured plastic panels in there and bam, there you go, a custom diffuer with little work that looks good for a cheap price. A little hot glue and some good ideas and you should be ok.
Hahaha! What did you use to cut the plastic without breaking it?
We laid the panels on stacked up cardboard and used a really sharp utility knife, making sure to measure it..twice, mark it, score it then make progressively deeper cuts till it was in two pieces...go slow, cut away, wear safety goggles...you know, be careful.
when i have to cut plastic like that i melt it lol.....otherwise get a dremel with a cutting disk amd for metals...it will saw through it like butter and cleanly as well.
or for a cheaper method a hack saw will work/pvc cutter.
Did you try looking around on the metal frame that held the diffuser. The manufacturers name might be on it somewhere with a phone number, or do a google search.
http://www.regentskylights.com.au/main/prisDiff1.html
http://www.patrickskylights.mx.com.au/diffusers.htm this isnt a tubular skylight right? cuase if soo there were a ton of tubular skylight diffusers..the rectangular ones were hard to find..but these might not even be your dimensions...best i could find though througha search |
Yes, they call it a "square tubular skylight". Those companies don't show the size I need, but it's a start! I'll call them tomorrow and see if they can make me one (21" x 21"). |
hahaha...i found it on google...where were you looking? lol....i earned a cookie.
What search words did you use? I'm gonna try whatever you did. :D
Google search SKYLIGHT :)
skylight diffuser.... lol.... i got a bunch of tubular skylights (so they ran in diameter measurments i think) but mabye i mis interpreted them..but i got a bunch
skylight 21" square diffuser order and I'm still not finding what I need. :( |
http://www.ebuild.com/guide/products...=0&sortCode=5#
here, i found a site that sells systems with 21" square diffusers. contact them and see if you can get just the diffuser. edit: found another link that may help. http://www.solatube.com/res_options_..._diffusers.php |
:eek: Thank you, Ent! :58:
bastard^^^ i was on that very ebuild page, but i jsut looked at the diagram/pics not the description so i thought it was tubular....sonofabitch.....
that optiview diffuser is BA looking though. lol. |
ps, that was the FIRST link that popped up in my FIRST search. just gotta know how to manipulate google ;). |
| All times are GMT -7. The time now is 06:25 AM. |
