Where can I get a diffuser?
Old Sep 24, 2006 | 03:23 PM
Z Car Barbie's Avatar
User Friendly
Arrrgh! I've been searching the net for hours, and still can't find a skylight diffuser (mine is broken). Lowe's, Home Depot, Ace and other hardware stores around here said they don't carry them. It's just a textured piece of clear plastic (similar to a florescent light fixture cover) that mounts slightly recessed on my ceiling. I looked up "skylight cover", but only found covers that mount on the exterior of the house, so that's not what I need.
Does anyone know where I can get one?
Old Sep 24, 2006 | 03:26 PM
why do you want to block your skylight? whats the purpose of getting one installed then? i have a skylight in my B'room lol...
Old Sep 24, 2006 | 03:38 PM
thxone's Avatar
Well you can look for ...crap what is it? I think they are called drop cealings or suspended cealings or something...my friend and I put up panels in his kitchen and they were textured...I don't know how big your skylight is but we had to cut down these pieces...and we got them from the Home Depot. I think after we cut them they were 18 x 32 or something close to that...I hope that helps you a little.
Old Sep 24, 2006 | 03:52 PM
User Friendly
Cuz without the diffuser, there's just a big whole in my kitchen ceiling, that's lined with silver insulation. The diffuser hides the insulation and tones down the light coming through, otherwise it's too bright. I'm constantly hitting the light switch to "turn off the skylight", thinking the electric lights are on. LOL!
Thanks. I thought about that, but it's not a flat piece of plastic - has a 1/2" lip where it mounts, then bows out in the center. I couldn't find anything similar to it at the home improvement stores. BTW, the entire panel is 21" x 21".
Old Sep 24, 2006 | 03:57 PM
thxone's Avatar
You can make a custom diffuser that drops in the middle, use some 1/4 dowels and make a frame then bring some dowels down to the center of the light and just put 4 triangular pieces of textured plastic panels in there and bam, there you go, a custom diffuer with little work that looks good for a cheap price. A little hot glue and some good ideas and you should be ok.
Old Sep 24, 2006 | 04:09 PM
User Friendly
Hahaha! What did you use to cut the plastic without breaking it?
Old Sep 24, 2006 | 04:15 PM
thxone's Avatar
We laid the panels on stacked up cardboard and used a really sharp utility knife, making sure to measure it..twice, mark it, score it then make progressively deeper cuts till it was in two pieces...go slow, cut away, wear safety goggles...you know, be careful.
Old Sep 24, 2006 | 04:38 PM
when i have to cut plastic like that i melt it lol.....otherwise get a dremel with a cutting disk amd for metals...it will saw through it like butter and cleanly as well.
or for a cheaper method a hack saw will work/pvc cutter.
Old Sep 24, 2006 | 04:48 PM
CanyonCarver's Avatar
Jack Of All Trades
Did you try looking around on the metal frame that held the diffuser. The manufacturers name might be on it somewhere with a phone number, or do a google search.
Old Sep 24, 2006 | 05:07 PM
http://www.regentskylights.com.au/main/prisDiff1.html
http://www.patrickskylights.mx.com.au/diffusers.htm
this isnt a tubular skylight right? cuase if soo there were a ton of tubular skylight diffusers..the rectangular ones were hard to find..but these might not even be your dimensions...best i could find though througha search
Old Sep 24, 2006 | 05:13 PM
User Friendly
Hmmm, I just went and checked, but didn't see any words or letters. It appears to be a makeshift job, and was installed when the house was built 5 years ago. Yah, I've been Googling all day.
Old Sep 24, 2006 | 05:23 PM
User Friendly
Thank you!
Yes, they call it a "square tubular skylight". Those companies don't show the size I need, but it's a start! I'll call them tomorrow and see if they can make me one (21" x 21").
Old Sep 24, 2006 | 05:26 PM
hahaha...i found it on google...where were you looking? lol....i earned a cookie.
Old Sep 24, 2006 | 05:32 PM
User Friendly
What search words did you use? I'm gonna try whatever you did.
Old Sep 24, 2006 | 06:22 PM
Jack Of All Trades
Google search SKYLIGHT
Old Sep 24, 2006 | 06:25 PM
skylight diffuser.... lol.... i got a bunch of tubular skylights (so they ran in diameter measurments i think) but mabye i mis interpreted them..but i got a bunch
Old Sep 24, 2006 | 06:27 PM
User Friendly
LOL! Yah see what that search gets ya. I'm currently searching with:
skylight 21" square diffuser order
and I'm still not finding what I need.
Old Sep 24, 2006 | 06:32 PM
entropy31's Avatar
The Cake Is A Lie!
http://www.ebuild.com/guide/products...=0&sortCode=5#
here, i found a site that sells systems with 21" square diffusers. contact them and see if you can get just the diffuser.
edit: found another link that may help.
http://www.solatube.com/res_options_..._diffusers.php
Old Sep 24, 2006 | 06:41 PM
User Friendly
Thank you, Ent!
bastard^^^ i was on that very ebuild page, but i jsut looked at the diagram/pics not the description so i thought it was tubular....sonofabitch.....
that optiview diffuser is BA looking though. lol.
Old Sep 24, 2006 | 06:44 PM
entropy31's Avatar
The Cake Is A Lie!
Originally Posted by Z Car Barbie
Thank you, Ent!
no problem, just my crazy ninja google skills.
ps, that was the FIRST link that popped up in my FIRST search. just gotta know how to manipulate google .
JohnnyB350Z
FS: 350Z / 370Z (03+)
Sep 15, 2009 10:10 PM
silverz32
Aug 25, 2009 08:37 PM
