Hey Nismopick...SHE LIVES (KZ440 LTD)
w00t!!!
They are twin carbs on the rear of the heads (like directly under the seat) right? My carbs are damn sticky too. Anything below 60 degrees it takes 5 minutes of cranking to get her started. Above 60 degress... starts right up. I haven't pulled the carbs tho because it looks like a biotch to do.
Lemme know how that goes...
w00t!!!
I hate to say it but it is easier than the ZX's to work on...but I still like the ZX's. If you plan to do it...which I think you should if you haven't, get yourself two large spay cans of Valvoline Throttle Body and Carb cleaner...by by varnish...this stuff is super good at cleaning gum and varnish and is the main reason this bike is running after sitting for 2 years. If you need ANY help I will help you out...it is actually fun to take the carbs apart and they are a very simple design with few major parts. The only weird thing is the way my bike vibrates my sac....ALOT....but it's all good!
i wish my car vibrated my sac i bet it feels like a massage for your nuts!!!
Now she lives! Sounds like it's running better.... and you cleaned her up.
I rebuilt the starter today...all new brushes and O rings...now she starts the first time everytime. I thought it was going to be hard to rebuild the starter but it only took like 15min once I decided to do it. I made sure to clean the armature real good and used some emery cloth where the brushes contact the armature then cleaned out the grooves...sounds cool when I push the start button, no more humming, grinding, whistling or anything...kinda sounds like it is using compressed air to kick it over but it does start really fast now. Next, fork seals.
Nice man. Feels great to get on a motorcycle that you made run right.
I started reading this thread, and watched the first video. First thought was. Did he synch the carbs? Sticking vacuum operated slides?
But, you got that figured out.
Are your carbs fully cable operated? Or are they the CV type that uses vacuum to lift the slide primaries? Classic Japanese bikes are a hobby of mine, but I don't work on the Kwaks much. Although a KZ1000 would be fun.
Sounds much better in the second vid.
Get the safety stuff fixed before riding!!
No bad tires, brakes, chain, lights etc.
Keep the shiney side up.
Got my front tire mounted properly...no more lump in the front tire and it is seated perfectly. Took her for a ride after the tire was fixed to see if the vibration was gone as before, as soon as I hit 50mph the lump in the tire caused the bikes front end to bounce a little and vibrate. I got her up to 65mph and it was perfect and smooth. I think I will try 70mph soon...since i have a good Shoei helmet...you know, the one Snw says is a waste cause my bike is an old crappy bike and not a race bike.
more money than necessary, at the very least, wrong style for that era bike, also, get a jacket if your going to be "testin" a bike out at those speeds that your unsure of lol.
Originally Posted by JBs280Z
Glad you got your tire fixed man. By the way I see you are STILL having sex with yourself................right now.
dude, why dont people ever see bikes coming? its cause they are ignorant and shouldnt have a license and probably would pull out infront of a speeding elephant. goto out fit, now just get a bike more fitting for the sport bike rider look lol
