having a problem blending...(paint question)
Old Oct 2, 2009 | 09:59 PM
Niku-Sama's Avatar
eff good grammar
ok so i got really bored and attacked the rust on my subaru and i got all the major parts that i want and i managed to get lucky and get a shade of white that matched perfectly to the shade of the car but i've run into a problem...
when i am trying to sand it down some, get rid of the over spray and try to blend in the area to the rest of the paint theres always a gap and the color of the paint goes from being the same color to a dirty grey look, whats up with that?
so far its only happened on 2 spots, the others are fine but its irritating because they are the biggest spots, right above the driver on the roof so of course you see it every time you get in.
Old Oct 2, 2009 | 10:34 PM
You're trying to blend rust?
What grit sand paper are you using? To feather, you should be using something in the range of 100-200 grit.
Old Oct 3, 2009 | 04:10 AM
Niku-Sama's Avatar
eff good grammar
even then theres still a big gap between the new paint and the old paint that you can see.
and no i am trying to blend the new paint into the old paint, its the same color but you can see where the spot stops of course and the new paint begins after i knock the over spray off with some 400.
i realized the greying is comming from the sand paper it self (the things you realize when your sitting on the throne) so i'm going to go to the store and try and get some non colored stuff for wood and see if that makes a difference. the automotive stuff isnt colored persay but its dar grey and the car is white and its probally leaving some behind causeing the greying.
as a side thought if the paint hasnt cured enough could it cause both of these problems?
its been a few days
Old Oct 3, 2009 | 05:14 AM
280zx2by2's Avatar
Haterade by da gallon!
build it up with bondo or any body filler if you have to
Old Oct 3, 2009 | 01:08 PM
skib's Avatar
This facepalm's for you!
are you wet sanding?
Old Oct 3, 2009 | 03:38 PM
Niku-Sama's Avatar
eff good grammar
i fail to see how that has any thing to do with blending paint
yep, wet
i've not had this problem on any other car i have touched up spots on, its werid. but this is the first white car so that might explain the greying part but the blending stuff is something different
edit:
just sanded down to primer and re sprayed, area got a little bigger this time. i can start over from scratch
Old Oct 4, 2009 | 06:24 PM
If you cut down a painted area to bare metal, you have to build it back up to match the level of the layers of primer / paint around it.
FYI... just sanding a circle into a panel will make it very complicated to match back up w/ the rest of the panel. Blending usually entails bringing the work to the edge of the panel (unless you don't care how it looks).
Old Oct 4, 2009 | 10:33 PM
Niku-Sama's Avatar
eff good grammar
oh no i meant the primer from the areas i had to fill so it was level.
i'm not going to bust my rump over it i've come to the conclusion is just the paint thats on it now its all funky any way and is causing the problem so i am just going to hit it with some 1000 wet and then buff it
besides i am just fixing some spots before i sell it
Murph Z32
18
Feb 9, 2008 04:11 PM
Carl's Z
Jan 17, 2007 08:45 PM
Zrolimit
Jul 12, 2006 03:21 PM
280ZX_AV8R
Jul 27, 2005 10:55 PM
rngrck
Dec 30, 2001 04:47 PM
