87 300ZX N/AT Grassroots Motorsports $2009 Challenge
4 Attachment(s)
This car was originally built for the Grassroots Motorsports $2007 Challenge, it also competed in the $2008 and $2009 Challenge finishing 7th overall in 2009
It started life as an 87 n/a automatic, I swapped to a 5 speed manual, tanked that motor and swapped to an n/a engine with only 1 bar of boost at which point it dyno'd 285 whp 349 lb/ft. I stripped and painted the whole car in and out, although paint and body isn't my strong suit and I laid it on thin and it's not looking so hot these days and could use a respray. The car ran a 13.1 with the turbo motor at 20 psi and only 13.8 with the n/a motor at 14 psi. The car does smoke under deceleration, not sure if it's the turbo or the rings, I did pinch and oil ring when I built the motor and reused an old ring as I couldn't wait to get a new ring in. It runs and drives no problem. ODO speedo don't work as I'm running the T5 in an 87 chassis (T5 used a cable to electronic sender, 87 used electronic sender at the trans) Coolant temp gauge works intermittently ( I added a coolant gauge, along with wideband and boost) Power steering has been removed. Power windows and locks all work. Hatch/fuel door release cable doesn't work (you can pop the fuel door form the inside). Bumpers removed (covers are there but no bumpers under). HVAC removed (heater core is in the car no fan or ducts (I have all the parts just not installed). battery relocated to rear Attachment 17885 Attachment 17886 Attachment 17887 I have tones of pics from the build as well as others, it's been in Grassroots Motorsports magazine in the Coverage of each event Attachment 17888 87 300zx (n/a) 86 T5 trans T3O4E 57 trim, water cooled, internal gate with 1 bar waste gate actuator home made DP CM turbo back exhaust Megasquirt n spark JWT 450 cc injectors Tial copy bov ebay vertical flow intercooler K&N air filter R200 CLSD (finned cover isn't on but comes with the car) Tokiko blues and springs in front Tokiko gas adjust and 88 turbo springs rear repainted 88 turbo wheels T Top shades and Bags comes with a huge mound of spares complete 88 "W" turbo engine (needs rings) mas, harness, ecu, turbo, injectors etc 88 Turbo trans FS5R30a (this is the one thats internally identical to the z32 tt trans) complete rear subframe with brakes (88 turbo) (minus the diff which is in the car) front struts, with brakes from 88 turbo (one springs isn't the correct 88 turbo) complete spare black interior bumpers HVAC I have all the pieces removed Spare rack and pinion along with all the power steering pieces to put it back on the car spare T tops 88 spoiler stock spare tire $4k firm for the whole deal, complete car plus tons of spares $3k for just the car and the pieces to make it while (power steering, hvac, bumpers) and then I'll deal with separating all the parts The prices are fixed, either it sells or it gets parted additional pic's of the car http://s116.photobucket.com/albums/o2/evildky/Z31/ additional pic's and info on the build http://forums.nicoclub.com/post4270042.html#p4270042 evildky@yahoo.com located in Louisville, KY 40204 |
