Used Full MSA Exhaust System
I have a 3-2 Headers and 2.5" Exhaust system with out Smog Fittings. This is for a Square Port Head. I am looking for $250, I am Located in SoCal.
I bought this kit to do a sound test for the car, I used it for about 200 Miles and have it stored in the garage, I am cleaning out the garage and don't want to keep all the parts.
Links below are what I bought.
Motorsport! MSA 3-2 Header, No Smog Fittings, 70-76 240Z-260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
I have the 2.5" Adpater
These outstanding headers are built especially for Motorsport to our strict specifications. The thick exhaust flange is flat machined to promote a consistent seal. It also prevents warping and eliminates the need for spacer height modifications. Exhaust ports have high-quality welds to ensure leak-free performance. Can be attached directly to the stock exhaust components or our Motorsport performance exhaust systems (choose stock or 2.5" adapter (pipe diameter of the exhaust you are going to use)). Special installation gaskets are included (do not use original equipment type exhaust gaskets with headers). This header configuration is for original 1970-1976 cylinder head "square" exhaust ports only. Replaces part number 15-6010 (same header).
Motorsport! Aluminized Performance Exhaust (For 3-2 Headers), 70-78 240Z-260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
Description:
This performance exhaust system was designed specifically for use with our Three-into-Two header, includes a front pipe sized specifically for connecting to a Motorsport 3-2 header Y-pipe, and has no provisions for retention of the factory pre-muffler or catalytic converter. This exhaust will work on 70-78 Z's with our 3-2 Header already installed (HEADER & Y-PIPE NOT INCLUDED).
Description:
southern-z
FS: 300ZX (90-96)
Nov 18, 2005 09:11 AM
25, 300zx, adapter, aluminized, diameter, exhaust, full, header, headers, kit, leak, motorsports, msa, msa32headers130, performance, review, z31
