ZDriver.com
-   350Z (Z33) Forums (https://www.zdriver.com/forums/350z-z33-forums-6/)
-   -   need help with with driver's side door !! (https://www.zdriver.com/forums/350z-z33-forums-6/need-help-drivers-side-door-18058/)
brim Apr 26, 2006 05:22 AM
I just had my 350z driver's door replaced (shield of the door) not the entire door anyways after looking at my new paint job which wasnt bad at all I noticed that when I open or close the door it just sound like a piece of metal like it isnt filled or connected to anything inside :paranoid: .it basicly sounds just like when you knock on your fender and you hear that empty metal noise. my left door doesn't sound like that at all soo...
I was wondering what can be done? is there anything that maybe they forgot to put in there? any help its appreciate it. I'm going back to the shop next week so I'd like to at least have an idea of what it is. thanks
SinCity350Z Apr 27, 2006 04:15 PM
The only thing I could think of is the safety brace inside the door. That safety brace weighs about 20 lbs, so do this...See if your driver's door is easer to open and close than the passenger side, and by easier I mean lighweight. If its not that and everything with the door works, its probably just paranoia and nothing to worry about :D.
rakeshsamual1 Mar 1, 2013 06:10 AM
Hey brim, plz go with this, here is all stem by description and images as well, it will definitely help u out : Howto: Remove/Replace Exterior Drivers Door Handle - Guides - 350Z & 370Z UK
soha Sep 16, 2013 12:21 AM
ok i checked the power at the fuse and it IS getting power. I did replace the HILI fuse but no change. I will attempt to check the relay now. any tips? does anyone have a diagram of the AC system, what should be plugged up the the compressor etc. ? thanks again!
