350Z (Z33) Forums Dedicated to 2003 + ZCars otherwize known as the Z33's
need help with with driver's side door !!
Old Apr 27, 2006 | 04:15 PM
SinCity350Z's Avatar
Las Vegas Moderator
The only thing I could think of is the safety brace inside the door. That safety brace weighs about 20 lbs, so do this...See if your driver's door is easer to open and close than the passenger side, and by easier I mean lighweight. If its not that and everything with the door works, its probably just paranoia and nothing to worry about .
Old Mar 1, 2013 | 06:10 AM
rakeshsamual1's Avatar
Hey brim, plz go with this, here is all stem by description and images as well, it will definitely help u out : Howto: Remove/Replace Exterior Drivers Door Handle - Guides - 350Z & 370Z UK
Old Sep 16, 2013 | 12:21 AM
soha's Avatar
ok i checked the power at the fuse and it IS getting power. I did replace the HILI fuse but no change. I will attempt to check the relay now. any tips? does anyone have a diagram of the AC system, what should be plugged up the the compressor etc. ? thanks again!
DeathByNissan55
Dec 13, 2020 03:42 AM
RSuave08
Feb 7, 2014 03:05 PM
TeknikL
FS: 300ZX (90-96)
Dec 7, 2012 03:10 PM
Black3Z
Dec 10, 2003 10:01 PM
Splice
Sep 11, 2002 10:19 AM
