350Z Performance / Technical Discussions related to Turbo charging, Supercharging, Engine, ECU, exhaust, and etc. performance enhancements and Techical related.
U.S. Spec to JDM spec...
Old 12-27-2003, 03:26 PM
Administrative Brown Guy
Riz Z Speed's Avatar
just for technacality's sake, this should be in Z32/tech
but to answer your question, I don't know what all the rage about JDM engines is lately. The JDM engines come with the automatic trans. cam profiles. That and they get smaller turbos than the U.S. spec motors. The JDM motors are rated at 280 but are usually measured at a little beyond that.
It's up to you on how you wanna spend your money. Having the lighter/stronger pistons, rods and rings done to your current motor will probably run you the same as swapping engines will. Unless you do the work yourself, of course. Then the difference will be the end cost of the parts. Replacing the bottom end is like essentially putting in a new motor.
Riz Z Speed is offline
Old 12-27-2003, 04:09 PM
Re: What year Z?
Originally posted by AllmyZs
Just curioys what year Z you are replacing the motor in.
He mentioned JWT Sport 500's. The 500 being plural, I'm guessing he has a Z32.
i.o.
FS: 350Z / 370Z (03+)
01-08-2014 09:13 AM
roneski
07-26-2006 04:22 PM
ZChief
02-10-2004 10:32 AM
raven1
09-30-2002 07:24 PM
4rdhater
08-28-2002 07:46 AM
Quick Reply: U.S. Spec to JDM spec...
