Help 350 is pulling right
I am a 280ZX driver and I and don't knpw alot about 350's. I have a friend that drives a 350. She is having problems with it pulling hard right. I have driven it and I can not figure it out. It has a tendacy to drift right at all speeds but that is not the BIG problem. She has replaced the tires, breaks, compression rods and has had several alinements.
The BIG problem is the car pulls hard right. My experiance is that it happens at 25 mph, 1000 rpm, but not all the time. Not sure if that is the only time it happens though. Athough this evening, while coming to a stop at a bumppy intersection, it again pulled hard right. The hard right pull does not happen at high speeds. Whats up????????????????? Is this normal for a 350????? she needs help and she is a fox so I would like to help her. > |
If she's had several alignments... what do the alignment shops say?
fox with a Z!!! dam!!! id check for a bent or lose sway bar or some crap like that(im not a suspension or any kind of car expert)
However it continued to pull hard right. Seemed to feel right for a day or two then - pull right again. |
While on a straight away at about 25mph - pull hard right. |
Have her take it to a "real" alignment shop. Most will put it on a laser rack and check it for free (or a minimal charge).
visually inspect tension rods. Even if toe is fine, if the caster varies per side it can pull to the side at different speeds.
of course, I've never even looked at the suspension on a 350Z :D |
Originally Posted by ZBRICK
OK will do. Anything else?
Originally Posted by Comorat2x2
Yeah, tell her to go back to the dealer and get her money back since they never fixed the original issue.
what pick sed^^^^ and the rest-----and bleachie has NEVER seen the underside of a 350......:017:.....make sure she is cuter than me, now....:042:ps--my experience has been that dealers have always lied to me---but a good indy shop with concerned workers---is another story.....go with her and watch them figger it out........hell, my beeter does that but is a plymododge omnirizon 2.2 and has bad struts and bad suspension and bad cv joints and bad.........her car should be still newish or something, should it not???/ :wink: |
The car is 2 years old, she bought it new, and it has never been in an accident. The dealer also replaced the breaks. They have suggested breaks, tires or alinement was the prob. She has done everything they suggested and still no fix.
Thanx everyone for your help (especially zhag because she is fine). I will suggest a racing shop. Anything else? . |
be dilligent.
I have never driven a car that drives so straight and true, even on angled or grooved pavement as my 350Z. It's handling is amazing. I hope I can get my 280ZX to drive half as good. |
