I Need Help!
Guest
Posts: n/a
I've got a 94 300zx non-turbo. My front bumper is cracked all to hell and I purchased a new front bumper. I decided to get a turbo front bumper because I liked the look of the air dams. When I took it to have it installed, they painted and sanded it and then found out it didn't fit. Has anyone else had this problem and can a fabrication be made to install a turbo front bumper onto a non-turbo car.
How does it not fit? All of the mounting hardware should be the same. Is it OEM or aftermarket? Some aftermarket bumpers fit very poorly. I'm guessing you didn't test fit it before doing any work. This is why they suggest you test fit them before sanding and painting.
Oh, 1 more thing. You should post this in the Z32 section, not the Z33 section. Just an FYI.
