Stage Charts
Stillen's Chart TT
1=Hi-flow Intake, 2=Exhaust, 3=computer, 4=pulley, 5=ignition upgrade, 6=flywheel, 7=intercooler, 8=boost controller, 9=racepipes, 10=cam gears, 11=injectors, 12=turbo upgrade, 13=exhaust manifolds, 14=NO Injection, 15=cams, 16=E.H.Plenums, 17=Pistons, 18=connecting rods Stillen's Chart NA 1=Intake 2=Exhaust 3=ECU 4=pulley 5=headers 6=ignition upgrade 7=flywheel 8=cams 9=E.H. Plenums 10=Nitrous SGP Racing's Chart for TT 90-96 Nissan 300zx-TT Staged Upgrades STAGE 0 Stock 280-300HP SGP STAGE I JWT POP Charger/Underdrive Pulley 305-325HP@10PSI Improved Low End Response SGP STAGE II JWT ECU Upgrade 365-380HP@12-14PSI Removes Limiters/Expands Fuel, Timing, and Boost Maps/Increases Boost SGP STAGE III SGP Test Pipes/Gut Pre-Cats 385-400HP@12-14PSI This Upgrade Will Shock You! SGP STAGE IV Cat Back Exhaust 400-415HP@12-14PSI No Exhaust Restriction/Great Boost Response-Car Pulls Hard SGP STAGE V Boost Controller 420-435HP@15PSI Steady Boost Response;Control/Solid 15PSI Of Boost SGP STAGE VI JWT NOS System 490-505HP@15PSI Car Shoots Out Of The Hole/System Engaged Until 10PSI SGP STAGE VII Intercoolers / Radiator Upgrade 495-510HP@15PSI A Must Have For Future Upgrades/Increased Cooling Efficiency SGP STAGE VIII JWT Twin POP 510-525HP@15PSI No Intake Resrtiction/Turbos Will Sing SGP STAGE IX Ported Trottle Bodies/Matched Intake 515-530HP@15PSI Car Now Ready For Injector/Turbo Upgrade SGP STAGE X 555 / 740 / 850cc Injector Upgrade 530-545HP@17PSI Now Able To Increase Boost/Upgrade Turbos SGP STAGE XI Sport 500 Turbos 555-575HP@17-21PSI If you plan to go above this stage, engine upgrading is suggested for durability reasons. The next stages will take you above 500RWHP! If you plan to take your Z over the 650RWHP mark, you will need a higher capacity Fuel Delivery system. please check the Fuel system section for more info on how SGP can help. Greddy TD05-16G Kit 560-605HP@17-21PSI SGP Racing TD05-18G Upgrade for the Greddy Kit (Cam Upgrade Required) 620-675HP@17-25PSI SGP Racing TD06-20G Upgrade for the Greddy Kit (Cam Upgrade Required) This kit has 650-750 RWHP Capability + SGP STAGE XII Cam Upgrade/SGP Head Package Package Includes Three Angle Valve Job, Port & Polish Race Package Includes Five Angle Valve Job, Port & Polish, New Valve Seats for the SST or Alloy Oversize Valves,& Bronze Valve Guides. Valve Springs, Cams, and Retainers are required for this level, and are not inluded in Race Package. SGP Racing's Chart for NA STOCK 222HP SGP STAGE I JWT POP Charger/Underdrive Pulley 238HP Improved Low End Response SGP STAGE II JWT ECU Upgrade 250HP Removes Limiters/Expands Fuel and Timing SGP STAGE III Exhaust (also ALC for Auto) 262HP Less Exhaust Restriction SGP STAGE IV Stillen Headers 279HP "Gain with NOS only" We ONLY Reccomend These for NOS cars,Better Low End Torque SGP STAGE V Ported Throttle Bodies and Matched Intake 290HP Improved Throttle Response SGP STAGE VI Injector Upgrade/JWT NOS System 390HP Hold On To Your Seat! SGP STAGE VII SGP Head Package Package Includes (Street or Race Port) & Five Angle Valve Job 420-430HP Better Throttle Response Z1 Motorsports TT Chart It even has pictures. TT.net member's stage chart By request, i've compiled these. By no means are these definitive. These are just recommendations and do not need to be followed to the letter. Naturally most of these stages are biased to what the vendor has for sale, so some stuff is missing. Driveshafts, different brand turbos, clutches, etc.etc. Feel free to use these as a guideline and edit as necessary for your application. |
| All times are GMT -7. The time now is 08:26 AM. |
