Stage Charts
Stage Charts
Stillen's Chart TT
1=Hi-flow Intake,
2=Exhaust,
3=computer,
4=pulley,
5=ignition upgrade,
6=flywheel,
7=intercooler,
8=boost controller,
9=racepipes,
10=cam gears,
11=injectors,
12=turbo upgrade,
13=exhaust manifolds,
14=NO Injection,
15=cams,
16=E.H.Plenums,
17=Pistons,
18=connecting rods
Stillen's Chart NA
1=Intake
2=Exhaust
3=ECU
4=pulley
5=headers
6=ignition upgrade
7=flywheel
8=cams
9=E.H. Plenums
10=Nitrous
SGP Racing's Chart for TT
90-96 Nissan 300zx-TT
Staged Upgrades
STAGE 0
Stock 280-300HP
SGP STAGE I
JWT POP Charger/Underdrive Pulley
305-325HP@10PSI
Improved Low End Response
SGP STAGE II
JWT ECU Upgrade
365-380HP@12-14PSI
Removes Limiters/Expands Fuel, Timing,
and Boost Maps/Increases Boost
SGP STAGE III
SGP Test Pipes/Gut Pre-Cats
385-400HP@12-14PSI
This Upgrade Will Shock You!
SGP STAGE IV
Cat Back Exhaust
400-415HP@12-14PSI
No Exhaust Restriction/Great Boost Response-Car Pulls Hard
SGP STAGE V
Boost Controller
420-435HP@15PSI
Steady Boost Response;Control/Solid 15PSI Of Boost
SGP STAGE VI
JWT NOS System
490-505HP@15PSI
Car Shoots Out Of The Hole/System Engaged Until 10PSI
SGP STAGE VII
Intercoolers / Radiator Upgrade
495-510HP@15PSI
A Must Have For Future Upgrades/Increased Cooling Efficiency
SGP STAGE VIII
JWT Twin POP
510-525HP@15PSI
No Intake Resrtiction/Turbos Will Sing
SGP STAGE IX
Ported Trottle Bodies/Matched Intake
515-530HP@15PSI
Car Now Ready For Injector/Turbo Upgrade
SGP STAGE X
555 / 740 / 850cc Injector Upgrade
530-545HP@17PSI
Now Able To Increase Boost/Upgrade Turbos
SGP STAGE XI
Sport 500 Turbos
555-575HP@17-21PSI
If you plan to go above this stage, engine upgrading is suggested for durability reasons. The next stages will take you above 500RWHP! If you plan to take your Z over the 650RWHP mark, you will need a higher capacity Fuel Delivery system. please check the Fuel system section for more info on how SGP can help.
Greddy TD05-16G Kit
560-605HP@17-21PSI
SGP Racing TD05-18G Upgrade for the Greddy Kit
(Cam Upgrade Required)
620-675HP@17-25PSI
SGP Racing TD06-20G Upgrade for the Greddy Kit
This kit has 650-750 RWHP Capability +
SGP STAGE XII
Cam Upgrade/SGP Head Package
Package Includes Three Angle Valve Job, Port & Polish
Race Package Includes Five Angle Valve Job, Port & Polish, New Valve Seats for the SST or Alloy Oversize Valves,& Bronze Valve Guides.
Valve Springs, Cams, and Retainers are required for this level, and are not inluded in Race Package.
SGP Racing's Chart for NA
STOCK
222HP
SGP STAGE I
238HP
SGP STAGE II
JWT ECU Upgrade
250HP
Removes Limiters/Expands Fuel and Timing
SGP STAGE III
Exhaust
(also ALC for Auto)
262HP
Less Exhaust Restriction
SGP STAGE IV
Stillen Headers
279HP "Gain with NOS only"
We ONLY Reccomend These for NOS cars,Better Low End Torque
SGP STAGE V
Ported Throttle Bodies and Matched Intake
290HP
Improved Throttle Response
SGP STAGE VI
Injector Upgrade/JWT NOS System
390HP
Hold On To Your Seat!
SGP STAGE VII
SGP Head Package
Package Includes (Street or Race Port)
& Five Angle Valve Job
420-430HP
Better Throttle Response
Z1 Motorsports TT Chart
It even has pictures.
TT.net member's stage chart
By request, i've compiled these. By no means are these definitive. These are just recommendations and do not need to be followed to the letter.
Naturally most of these stages are biased to what the vendor has for sale, so some stuff is missing. Driveshafts, different brand turbos, clutches, etc.etc. Feel free to use these as a guideline and edit as necessary for your application.
1=Hi-flow Intake,
2=Exhaust,
3=computer,
4=pulley,
5=ignition upgrade,
6=flywheel,
7=intercooler,
8=boost controller,
9=racepipes,
10=cam gears,
11=injectors,
12=turbo upgrade,
14=NO Injection,
15=cams,
16=E.H.Plenums,
17=Pistons,
18=connecting rods
Stillen's Chart NA
1=Intake
2=Exhaust
3=ECU
4=pulley
5=headers
6=ignition upgrade
7=flywheel
8=cams
9=E.H. Plenums
10=Nitrous
Staged Upgrades
STAGE 0
Stock 280-300HP
SGP STAGE I
305-325HP@10PSI
SGP STAGE II
JWT ECU Upgrade
365-380HP@12-14PSI
SGP STAGE III
385-400HP@12-14PSI
SGP STAGE IV
Cat Back Exhaust
400-415HP@12-14PSI
SGP STAGE V
Boost Controller
420-435HP@15PSI
SGP STAGE VI
JWT NOS System
490-505HP@15PSI
SGP STAGE VII
495-510HP@15PSI
SGP STAGE VIII
JWT Twin POP
510-525HP@15PSI
SGP STAGE IX
515-530HP@15PSI
SGP STAGE X
530-545HP@17PSI
SGP STAGE XI
Sport 500 Turbos
555-575HP@17-21PSI
Greddy TD05-16G Kit
560-605HP@17-21PSI
620-675HP@17-25PSI
SGP STAGE XII
STOCK
222HP
SGP STAGE I
238HP
SGP STAGE II
JWT ECU Upgrade
250HP
SGP STAGE III
Exhaust
(also ALC for Auto)
262HP
SGP STAGE IV
Stillen Headers
SGP STAGE V
290HP
SGP STAGE VI
390HP
SGP STAGE VII
SGP Head Package
420-430HP
