z32 no start
z32 no start
I have a 93 z32 I was check in my pcv valve so I moved the harness that covers it alil to see it and now it won't start I moved the harness down nd it started but if I touch it it shuts off has anyone ever had this issue I wana kno if its comin nd if its a specific spot b4 I take **** apart lol
Finally had a chance to check it out checkd for codes I got one slow one fast on the papers I got for the code list one says cam angle sensor the other says crank angle sensor so if anyone knows wich one it actually is would apreciate ....nd the other code was 13 engine coolant. Temp let me kno would apreciate all the help I can get .....teloz32@gmail.com email me if u know what's up
It's ****ing simple, google z32 CAS location or simply fallow the wiring harness you moved and check the connectors attached to it.
Ok so I checked the cas checked the connector. Pins look fine I opened the harness where I moved it no wires look striped everything look fine so I started it turned on ran for acouple mins then died out I turned it back on hesitated alil but turned on then shut off again nd then wouldn't start I check for codes again all I got was 13 coolant temp sensor so yea lol
bongpogi
08-19-2015 11:15 AM
moorebl
04-14-2011 03:28 PM
