Z try's to start then clanks to a stop
Old Jul 18, 2014 | 10:18 PM
97gtp's Avatar
I have replaced all these things: spark plugs coil packs, coil pack wires, new ptu relocation kit from z1. I just bought a cas and I've checked the timing belt. A fuel injector and I've done the resistor trick to the car to the knock sensor bs- I've been doing nothing but trying to get this car to run normal since I bought it, and as soon as i have narrowed the issue of dead cylinders down and I take it to complete the new coil pack install and replace a proven bad injector, on start up now it won't start...
The car was sitting for about a week so when I got home and fired it up it kept wanting to die at idle, so I had to keep revving it to keep it alive at stop signs and stuff. I thought maybe it was a battery issue simce it sat for a while and with all its issues it never gets driven anywhere far. so i took it on the free way (in hopes to let the alternator charge the battery)and when i got off the freeway it was still doing the same thing. not quite as bad but it would still get low on the idle and wanna die. So I parked it and put in a fuel injector to solve my dead cylinder problem. I went to fire it up and when i did it then Made an abrupt clank noise and stopped. I Tried to start it again and it wouldn't even put the same effort as it did at first. it just sounded like the engine wouldn't turn at all. If it sits for a while it would give one good effort and the shudder to a halt. And repeat the same thing as I just mentioned. After this I received a code 11 and that's when I bought a used good condition cas to see if that solves the problem. It did not, it did the same thing, Tries to start for a second then a loud clang noise and it stopped then every attempt after just seemed like the engine couldn't turn over. I have no clue what the hell is the issue I can check fuses maybe check some relays. Right now after installing the cas and clearing code 11, I have 55s I tried starting it several times and still 55 so I'm not sure if the obd will pick that up since the car hasn't fired up completely or if it just reads 55 because I replaced a bad cas. Does anyone have any ideas to what this clanking no starting crap could be? Please help!
Old Jul 19, 2014 | 10:06 PM
97gtp's Avatar
anyone????
Old Jul 19, 2014 | 10:49 PM
zxguy1986's Avatar
Welcome back to ZDriver!
This site is trying to help Z owners. All of them. Zs have been produced since the 1970s. You can still can buy a brand new one in 2014. Think about how many models that is...
Did you say in your post what model and year your Z is, transmission, mileage, mods or not? Oops. Looks like you forgot. If you don't give our guys the info they need, they pass on your post. Yeah, you do have a problem - but... with what Z?
Nobody really needs guesses when they have a problem - and nobody likes to post them here either. We can do it but it's really a waste of time in the long run. So just give us the info we need for starters - and someone will be happy to tell you what they know. Thanks for your help!
Old Jul 19, 2014 | 11:05 PM
PredatorZ's Avatar
alternator
Take it to an auto parts store, they can test the alternator, I bet it is almost dead
Old Jul 20, 2014 | 12:05 AM
97gtp's Avatar
The altanator was going to be one of my next attempts. Maybe an ignition relay. I will have to take it down and have it tested.
I have a 1990 300zx na 5 speed and it has about 175k on it. I just bought it a month ago and I've just been fixing all of its quarks.
280zx2by2
Aug 6, 2009 08:06 AM
z-hag
Jun 8, 2009 07:25 AM
VegasEdge
Jun 3, 2005 03:06 PM
BlackZ
Apr 28, 2005 02:10 AM
TpaLightningFan
Apr 14, 2003 01:52 PM
