where are they?
Old Dec 12, 2003 | 12:26 PM
pearly whites's Avatar
turboZdriver
where are they?
where are my turbos in my 91 z? i know there there, i just cant see them.
by the way...if they go up, how much are they to replace? replacement stock turbos?
Old Dec 12, 2003 | 03:41 PM
Copper727's Avatar
Gold Member
Hey, good news! There's ONE available for sale on eBay that I can find, and it's located on the following link:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2447209823
Good luck...
Old Dec 12, 2003 | 08:11 PM
emo236's Avatar
confuzed member
your turbos are located right on the inside of your fenderwalls, on the bottom of your motor. They're not really visible if you're just looking into the engine bay. Also, have you considered upgrading turbos. I mean, why not? you're going to have to dump money into new oem turbos which aren't cheap either and all the labor or DIY. If you wouldn't mind more power, might want to think about it. These are very nice!
http://conceptzperformance.com/Cart/...4768.7.122.240
Old Dec 12, 2003 | 09:49 PM
Riz Z Speed's Avatar
Administrative Brown Guy
http://www.jimwolftechnology.com/customer_results.asp
http://www.boost-solutions.com/turbos.htm
http://store.yahoo.com/sgpracing-store/turkittur.html
http://www.specialtyz.com/jimwolf.htm
http://www.z1motorsports.com/Product...bos/Turbos.asp
Here's a good selection of turbo upgrades for you. Should keep you busy for awile.
The most popular around here tend to be the JimWolfTechnology and the PE(Power Enterprises). The HKS and others are ok too.
Careful though this isn't an easy job. You'll have to pull the engine to swap those out. Be prepared or find a good shop. While you're doing that though you might want to consider doing other upgrades as well like larger intercoolers, hard pipe kit, larger radiator(you'll need it eventually especially with larger turbos), larger fuel injectors, maybe some tranny stuff(lighter flywheel, lighter one-piece driveshaft, N/A differential, different limited slip system).
Once you start you cant stop!! lol
Old Dec 13, 2003 | 03:11 PM
turboZdriver
before i go throwing down all sorts of money. i wanna make sure its my turbos going up. theres a rubbing scratching sound coming from each side of the car near where the turbos are.. anyone had turbos go up on em? is this sound problematic...? im new to turbos. if ya cant tell....
