Weired Interiro Noise
Old Feb 8, 2008 | 06:31 PM
Darkmann's Avatar
It's not a shriek, it's not a rattle, sounds like a small bearing noise, but more like the old deskjet printers with the soft sound quality of a whistle. Comes on shortly (10-15 minutes) after the car starts rolling, an goes away shortly after the car stops rolling, motor running. There's no real pattern to it, sometimes short bursts, some time a long burst the short, just random in duration and period. It's however not a steady shriek - well, not yet. On driver's side the shriek seems to be coming from the passenger door area, from the passenger side it seems to be coming from the driver's side door. From dead center, it seems to be coming from the pod on the center of the T-Top "H." I haven't checked my service manual yet, but there's got to be some kind of fan in that pod - I can see breathing slits on that pod. Could that be the source? It just started this morning and it's driving me nuts!!!
Old Feb 8, 2008 | 06:47 PM
entropy31's Avatar
The Cake Is A Lie!
probably the Climate Control Sensor fan. pretty common.
Old Feb 8, 2008 | 06:57 PM
Darkmann's Avatar
Thanks man. One more thing to pull out this weekend, depending on weather. BTW, any clues as to how to take the pod down? Is the fan serviceable or just replace it?
Old Feb 8, 2008 | 07:35 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Replace it, and as he said, it's a very common problem. How to remove it? I couldn't tell you... I've been fortunate enough to never have one fail on me. =D
Old Feb 8, 2008 | 08:21 PM
Barry'Z(NJ)'s Avatar
General Z User
There is an adjustment screw on the fan, I used it to fix mine.
Old Feb 12, 2008 | 10:53 AM
Darkmann's Avatar
I pulled it out, lubed with some lithium grease - for some reason the noise got worse - constant steady whinning!!!! I then adjusted the screw (even though I have no idea whether I advanced or slowed fan speed!!!!!) and the noise is gone - well, for now. I called my local Nissan shop and ordered a replacement unit!!!!!!!!! Now I hope the replacement unit comes already adjusted.
turbojohnny
30
Jun 18, 2009 10:36 PM
Darkmann
Mar 25, 2008 09:30 PM
Z_lover
Aug 13, 2007 04:30 PM
79bigbore280zx
Oct 27, 2003 10:36 AM
SwiggA88zxt
Apr 23, 2002 03:15 PM
