ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   Weight Difference? (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/weight-difference-3653/)
ZxJR Oct 3, 2002 06:58 PM
Weight Difference?
In several reviews I've read the NA weighs 3,474; 2+2 3,219; and TT 2,835. I would think the NA would weigh the least. And i really don't understand how the 2+2 weighs less than the NA. Is this true? Would this mean the 2+2 might be a little quicker than the NA is stock forms? Please give me any info on this and the right info if this isnt correct. Thanks
Craig_Paterson Oct 3, 2002 10:47 PM
Re: Weight Difference?
I'm not a positive about this but i don't believe that is correct..at least on the z31's the 2+2's are extended longer as well and are a bit heavier...the turbo's don't weigh too much so it shouldn't be a very large factor in weight..that is one of the main advantages of having them as oppose to just a bigger engine..
uztv Oct 4, 2002 09:05 AM
Here is what I have for the breakdown. Perhaps someone has a service guide that shows this to verify it.
1473 kg (3240 lb.) [2-SEATER]
1561 kg (3434 lb.) [2+2]
1612 kg (3546 lb.) [TWIN TURBO]
..Dan
ZxJR Oct 4, 2002 01:06 PM
Ok. That seems right.
Thanks
