water pump
Old Dec 20, 2010 | 02:08 AM
roger mallorca's Avatar
water pump
any body give idea how to removed my water pump for my 300z non turbo
im having difficult . thanks
Old Dec 20, 2010 | 10:06 AM
ttxz003's Avatar
According to alldata for a 93 NA:
drain coolant, remove undercover, radiator, drive belts, cooling fan & coupling, water inlet & outlet, crank pulley, and timing belt cover
Remove water pump
install in reverse
there may be shortcuts, but I couldn't tell you.
Old Dec 20, 2010 | 05:49 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
There aren't really any shortcuts... that's what it takes. Since it's a bitch to replace, make sure you do it right.
Old Dec 20, 2010 | 06:22 PM
ttxz003's Avatar
if this helps, you can see its burried
Old Dec 20, 2010 | 06:34 PM
thanks ttxz003 , my problem is to remove that lower cover thanks for hints
nismo619
Oct 31, 2006 10:03 AM
Aphrodite
Feb 10, 2006 06:30 AM
JAMESZ
Apr 15, 2004 08:24 PM
zguy36
Apr 14, 2002 02:59 PM
katkins
Sep 4, 2001 07:32 AM
