i have a na 300zx should i just put a tt in it and a manual trans im pretty pissed about this someone tell me which direction to go in
Dan's the Man
I'm assuming he has an N/A, auto. The auto trani went and he's pissed.
Soooooo. If the auto trani is the problem you have several options...
1) replace/rebuild your auto trani ($$)
2) swap in a Manual trani ($$$$)
3) replace/rebuild your n/a auto trani with a TT auto trani and swap in the TT engine ($$$$$$)
4) swap in a manual trani and TT engine ($$$$$$$)
5) sell it and buy a TT (manual or auto, take your pick)
What do you want out of the car? How much can you afford to spend? Can you do the work yourself?
Is this your only means of transportation?
Bad Speller
ohh uhhm well lemme bring out my Bardabese dictonary. (murmurs). ... .... oh ..... uhh.... ok....uhm ..... yeah got it! I belive what he is trying to say is that he has an Auto N/A. and he's asking if it's cool to put in a MAnual TT transmission in it? or if there areany other suggestions.
Dan's the Man
Quote:
and if anyone has a manual tranny, clutch and flywheel for sale.Originally Posted by bardabe
Which coincidentally you do!
Replace tranny yourself (AT or TT) = $1500-2500
Pay For Shop Tranny Rebuild (AT) = $2500 +/-
Pay for Shop Tranny Swap (TT) = $2500-3000
Replace Motor + Tranny Yourself (AT or TT) = $5000 (conservative) + and a whole lotta time and money
Pay For Shop Motor + Tranny Swap (TT) = $6000 + a whole lotta money (but less time).
Dont forget every route except for the rebuild includes having to pay for additional parts to swap in, which is also going to cost you.
I went the route of paying for a rebuild when mine went out, it cost about $2500, but a year later its holding up like a champ. I would only suggest a TT MT swap if you've got a place to keep your car for the next few months to a year and only if you've got some way to afford the neverending problems your probably going to encounter. OR if you've got the money to just pay a shop to get it done, in, out, and done with, cause otherwise, its going to be a lot harder than it sounds.
Bad Speller
actually to swap for Manual to auto it's nto hard or expensive.
Manual Tranny clutch and flywheel. 550$
shifter bushing 6$
Shifter linkage, shifter, pedal, slave cylinder, and hard lines 300$.
slave cylinder, 30$
Gear Oil. 30$
labor time of you do it yourself. 1 day.
labor for me to do it. 500$
and that ios areally rough estimate. liek rough as really rough like 25 grit sand paper rough.
shifter bushing 6$
slave cylinder, 30$
Gear Oil. 30$
shifter bushing 6$
slave cylinder, 30$
Gear Oil. 30$
actually to swap for Manual to auto it's nto hard or expensive. Manual Tranny clutch and flywheel. 550$
shifter bushing 6$
slave cylinder, 30$
Gear Oil. 30$
Why not just say you have no clue?
only 25 grit? **** I'd say like 3 grit, like the rock from your backyard type of rough. J/K...good estimate
