Timing Belt
I'm about to get my timing belt changed on my Z and i'm thinking of doing it myself. i've read many sites on what to do and what you need but the only thing i didn't see mentioned was setting the timing. and i saw somebody post a message up on here saying you don't set the timing on a Z. can someone explain this somemore? i appreciate all the help. thanks.
glenn |
there is no need to set the timing when u do the timing belt, check the write up on ttzd about that, when u do the timing belt, every thing should line up perfectly, and therfore when your timing was, it still is :)
