Things look better for the n/a guys
Old Nov 26, 2005 | 08:58 PM
CanyonCarver's Avatar
Jack Of All Trades
N/A with bolt-ons gets 228 RWHP .............. Dyno chart included.
Cams might be a stretch for bolt-ons for some.
Old Nov 27, 2005 | 04:05 AM
Riz Z Speed's Avatar
Administrative Brown Guy
omg i wish i had that torque curve.
the hp line isn't bad either.
too bad he's going TT, i'd like to see how much more he could do with the NA.
Old Nov 27, 2005 | 09:28 AM
91zxtt's Avatar
How much do you think someone could squeeze out of an N/A without nitrous? They could port and pollish the heads, go with stock TT injectors, pistons, rods, then hone the plenum and intake manifold. What do you think, maybe 275 at the wheels? That would still be damn good on this motor.
Old Nov 27, 2005 | 10:44 AM
Jack Of All Trades
I'm not saying much because it's all theory, and I'd get my *** flamed off for typing about it.
Old Nov 27, 2005 | 11:49 AM
emo236's Avatar
confuzed member
I would think that numbers about right. Maybe more if they fabbed an individual throttle body intake up and some other stuff.
Old Nov 27, 2005 | 01:46 PM
Jack Of All Trades
More likely if someone put in bigger valves and actually ported the heads to complement the cams with the porting work being done based on what you see on a flow bench. You wouldn't need itb's, maybe something like a custom upper plenum with one vq35 throttle body and maf sensor.
Old Nov 27, 2005 | 01:55 PM
emo236's Avatar
confuzed member
you don't think that an NA would benefit greatly from itb's (I like that abbrev.)? Why not? I mean, it'd suck to synch them all, but I think it'd greatly improve throttle response and flow. Correct me if I'm wrong, since I probably am.
Old Nov 27, 2005 | 03:59 PM
Jack Of All Trades
I think itb's would make an improvement. Like maybe 6 throttle bodies from a 1200cc v-twin f/i motorcycle or something. And then 6 little K&N's. And then an adapter, to the lower plenum? Or make a lower plenum block-off plate and mount straight to the heads with an adapter plate on each head. You're right, tying them all in to the throttle could be a challenge.
I'm not being facetious. ..... I'd guess that the t/b's and filters alone would run $1500 - $2k.
You'd still need to get some head work done to see any big improvements.
Old Nov 27, 2005 | 04:37 PM
emo236's Avatar
confuzed member
I'm definitely not assuming that it wouldn't be worth the cost. it woudln't IMO. I've seen ITB setups on Z's that were pretty impressive. This is also assuming that everything that can be done has been done. This is after all the ultimate NA Z we're talking about.
Old Nov 27, 2005 | 04:48 PM
emo236's Avatar
confuzed member
Here's some examples that I found.
Attached Thumbnails Things look better for the n/a guys-carbon-intake.jpg   Things look better for the n/a guys-japan_plenum_002.jpg   Things look better for the n/a guys-manifoldmod17.jpg
Old Nov 29, 2005 | 09:47 PM
91zxtt's Avatar
I like that 1st one. It's such a clean setup. I wonder what power gains were seen with that?
Old Dec 1, 2005 | 04:30 PM
tay-fu300zxtt's Avatar
nice! My daily driver is a n/a with 202,378 miles
KasbeKZ
Mar 29, 2010 01:03 PM
skittle
Mar 1, 2007 02:33 PM
CrAzY_84na
Jul 12, 2004 06:06 PM
SoloZ
Jun 17, 2003 11:05 AM
BigTDogg
May 7, 2002 09:10 AM
