whats first?
Old 10-07-2003, 08:46 AM
turboZdriver
pearly whites's Avatar
whats first?
Bone stock 1991 300ZX Twin Turbo. What's the first performance upgrade i should look into? I know i need to get a turbo timer. I was considering the Blitz FATT DCII turbo timer. Intake? Exhaust? Chip? Turbo upgrade?
pearly whites is offline
Old 10-08-2003, 01:16 PM
Administrative Brown Guy
Riz Z Speed's Avatar
How much money ya got? It all depends on how deep your pockets are. If you can afford to get a lot of goodies at once, more power to you. Usually the simplest upgrades are done first. Intake, exhaust, gutted cats/downpipes,pulley, ignition upgrade, flywheel, intercooler,boost controller, adjustable cam gears, larger injectors, ECU, dual intake filters, turbo upgrade, exhaust manifolds, cams, extrude honed plenums, bottom end (pistons, rods, or stroker kit), heads (titanium valves, guides, springs, valve job, etc). Most of this should be grouped together (done at the same time). The more you do at one time the more dramatic the effect, obviously. Don't forget you'll probably want to leave room in your budget for suspension, wheels and tires, possible body kit, interior accessories, and so on.
Riz Z Speed is offline
feathersem
05-11-2010 09:40 AM
81 Black L28E
12-22-2005 07:12 PM
pearly whites
07-18-2004 03:05 AM
njordal02
12-17-2003 02:59 PM
CrAzY_84na
09-23-2003 07:00 PM
Quick Reply: whats first?
