Solved!!!!
Solved!!!!
I forgot to form you all what my electrical issue was.
So I get under the car and check the starter wires. Everything is mad tight. Like a 12 year old. ((sorry to any 12 year olds on this))
The car starts up like normal. Then I drive it off my ramps and turn it off, try to start it again and it dies. Son of a bitch!!
I dont know what this is so I slam the door and the power comes back on. I turn on my headlights and decide to jiggle around some wires under my hood. I just BARELY touch my negative terminal and the lights die, so im thinking I need a new terminal. So I get my dirty *** to Advanced Auto and hook it up with a new terminal. I get home.
As I go to take the terminal off the battery I pull that hole little wire right off of the car. BLASTED!!!! its not the terminal. It was the ground. The problem is solved.
Now. I saw something about some dude and his heat. My heat doesnt get that hot unless the car has been running for mad long. When it does finally get hot it only blows hot from the center vents. Whats this about.
P.S. That 12 year old comment.... I do not discriminate, boy or girl, use your imagination.
I need to wash my car since I took her snowbaording today and she got filthy from that snowy muddy parking lot.
You COMPLETELY redeemed yourself until this part.......
datto
May 11, 2001 04:23 PM
