Rough Idle
Old Apr 3, 2003 | 07:15 PM
silvrhand's Avatar
Snazzy Title
It could be quite a few different things, run some fuel injector cleaner through it, check the air filter, make sure there are no vacumn leaks, using some soapy water or a can or carb cleaner is good to spoot boost leaks and so on.
Do you have an aftermarket boost gauge? Does it sit at a good vacumn while idling? Could be just something little or you could have something more troublesome such as the CAS (crank angle sensor)
MR2ZX
Feb 11, 2013 09:25 AM
ryencoke
FS: 300ZX (90-96)
May 18, 2012 11:45 AM
Sp4rt4n
Oct 13, 2006 12:55 PM
jbaran1123
Nov 8, 2002 07:01 PM
jbaran1123
Sep 11, 2002 01:03 PM
