Resonators Or Not???
I'm going with the Greg Dupree test pipes (DP's also) and you can get them with or without the Resonators. I know that they quiet your car but don't know how much. I don't want it to be too loud (in a bad way), Meaning you can put Flowmaster or Borla etc. on a new Corvette and it sounds great (louder is not alway better with Japanese cars). I plan to bring my car up to 400WRHP and I'm also getting the HKS SSQV so if this helps could you please give me your opinions
You're missing my point, I like good sound and I realize that when you have a car that has 400hp it's going to be lounder than your average car. Although this is my second Z (no high performance parts on 1st one) I really have no knowledge of what it's going to sound like and the Japanese cars that I do see on the road that are loud are Civics and that deffinately isn't the lound sound that I'm looking for. This is why I explained about loud being good on a Corvette with Borla exhaust, but that car doesn't wake up the whole damn neighborhood either.
A 6Cylinder is never going to sound like a Civic, so don't worry about that. I have resonators on my Z and it sounds pretty good. It's loud enough to turn heads and it's deep but not loud enough to upset anyone. I got it from Specialty Z though, it's a Labree exhaust.
Originally Posted by b300z
ive heard many 6 cylinder cars that sound like hondas....
NA's have volume problems with aftermarket systems. Greg's are very straight and hence a bit louder. TT's have a natural baffling effect due to the turbo's so resonators are not as critical as NA's. I expect that you would be pleased either way, but if this is a daily driver, you may want to go with the resonators.
(Keep in mind that keeping a car "quiet" and hotting it up to over 400HP is somewhat anthithetical.)
BTW - The resonators that Greg uses will help curb the raspiness which is what most folks are actually complaining about when they make references to Civic and ricers.
Thanks guys!
I wouldn't. I have Specialty Z's downpipes and mid-pipes (w/hi-flow cats) and the Stillen Cat-Back. It's not loud at all. Nice low growl at idle with an aggressive, yet responsible tone. I kinda disappointed that ASH would recommend resonators on a TT. They're not necessary. I don't even think my car is as loud as a stock N/A.
Q: IS NISMO THE ONLY COMPANY THAT MAKES INJECTORS FOR MY CAR OR IS THAT JUST THE BEST CHOICE. I WAS ALSO TOLD THAT I NEED (6) OF THEM IS THIS CORRECT.. ALSO I HAVE A QUESTION ABOUT RESONATORS, SHOULD I GO WITH OR WITHOUT THEM. I WANT MY CAR TO HAVE A GOOD SOUND BUT I DON'T WANT IT TO BE LOUD AN AGGRIVATING
A: Border also makes injectors, as well as power enterprises. Do a search for them and you should find some vendors with them. You will need 6 of them, yes. If you are wanting a reasonable exhaust note, I would stick with resonators – they dampen the raspyness of the exhaust note and quiet the entire sound a little.
Good luck!
-Ash
Please excuse the caps I'm not yelling I'm just use to typing this way.
Unless he didn't realize you have a TT; which he should have since an injector upgrade is uncommon in an N/A. If you go with the downpipes, midpipes w/hi-flow cats and the cat back system without resonators, you will not be disappointed. Raspy would never be a word I would use to describe how my exhaust sounds. I disagree with him.
Are you going to have the hi-flow cats on it, or just the test pipes? If you won't have any cats, then that combined with the HKS Hiper could get it to where it borders on raspy/annoying. Your call.
RIGHT NOW I JUST HAVE THE STOCK TEST PIPES AND DOWNS, EVERYTHING AFTER THAT IS THE HKS: http://www.hksusa.com/products/more.asp?id=715 THE GREG DUPREE DP/TEST PIPES I'M GETTING A LITTLE LATER. SO TO ANSWER YOU QUESTION THE ANSWER IS YES. THIS IS NOT MY Z BUT THIS GUY HAS THE SAME LOWER EXHAUST SYSTEM. http://www.hksusa.com/products/more.asp?id=715
PLEASE EXCUSE THE CAPS.
