Radiator hoses swelling
Old May 28, 2010 | 10:24 PM
JR100285's Avatar
hello everyone,
i have a TT motor in a n/a body and i want to know why there is so much pressure building up in the radiator hoses. its causing them to swell up and popping out of place. it literally punched a hole right through the upper radiator hose causing coolant to spill everywhere. whats wrong with it?
Old May 28, 2010 | 11:13 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
... the hoses are bad. Replace them. Make sure to get hoses designed for the cooling system, preferably the ones from Nissan made for the 300ZX. (You can't just use any hose and expect it to hold up to the heat and pressures combined.)
Old May 29, 2010 | 05:22 PM
luis88's Avatar
mine was the same it had a small hole i didnt noticed it since it was in the bottom part once i took it off and i inspected it by folding it thats when i saw the hole
i replaced it and problem solved
Old Jun 2, 2010 | 11:26 AM
napoleonzheking's Avatar
F5 Hero
It's either that (bad hoses), or a bad head gasket causing him to boost his coolant system..
HexaggramJDM
Jul 13, 2011 07:06 AM
raythenegr0
Dec 7, 2007 08:23 PM
CanyonCarver
May 1, 2005 10:00 PM
dpardo
Oct 15, 2003 08:48 AM
phattie
Sep 7, 2003 10:19 PM
