ProFec B spec 2 settings
Old Aug 28, 2005 | 01:00 PM
Mousier158's Avatar
anyone else running a Greddy Profec B spec 2? I am trying to get the best settings...still rinning stock turbos Your input is appreciated
Old Aug 28, 2005 | 05:00 PM
91zxtt's Avatar
Remove the factory clock and mount it there.
Old Aug 29, 2005 | 04:44 AM
Mousier158's Avatar
sounds like a good place to mount it but im alreday set up i just want to know what settings people are running.
Old Aug 30, 2005 | 05:24 PM
Mousier158's Avatar
apparently no one else has a Profec B spec 2?? ?? any takers?
Old Aug 30, 2005 | 06:41 PM
Z Addict's Avatar
I have one but I can't help ya sorry my Zs not turboed yet
Old Aug 31, 2005 | 09:07 PM
91zxtt's Avatar
Damn,...I didn't read that at all.
Sorry, no help here. Haven't driven mine enough to get the settings right.
Old Oct 1, 2005 | 09:04 PM
MadZ420's Avatar
i'm running 47% set Gain 35% and SET GAIN is 17.5 waraning is 21.5 limiter is 15%. You do have the pontental to run 20psi on stock tt engine but not recomended. I'm running 16.5 psi on mine. I love the profec B Spec is great.
Old Oct 1, 2005 | 10:29 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
should've gotten an Apex-i AVC/R if you ask me... set the boost level and leave it alone, let it figure its own duty cycle out... can't beat self learning electronics =D
Old Oct 2, 2005 | 06:47 PM
MadZ420's Avatar
Ya I do like those but my purchase was spur of the moment. But I do like the control I have with the B spec.
Old Oct 2, 2005 | 11:55 PM
Mousier158's Avatar
I was unaware the Apexi unit was self-learning. However, i am very plaesed with the ProfecB!!
Old Mar 27, 2006 | 06:43 PM
1SIKZ's Avatar
That apexi AVC/R uses fuzzy logic to making it "self learning"... It is NOT recommended to use Fuzzy logic boost controllers with turbo turbo setups that are in parrellel.
Old Mar 27, 2006 | 06:47 PM
1SIKZ's Avatar
Has anyone had any problems with the Greddy profec B.. I have heard that the stepping motors go on them and that is a problem with that boost controller... Has anyone ever had this problem?
Old Mar 27, 2006 | 07:49 PM
MadZ420's Avatar
Wasn't aware of any motors in the controler. I thaought it was all electronic, with the vacum selonoid. But not a single problem with mine, I love it.
Old Mar 28, 2006 | 02:34 PM
1SIKZ's Avatar
are you running stock turbos? and if so how much boost can you run on stock turbos and injectors?
Old Mar 28, 2006 | 08:54 PM
MadZ420's Avatar
Um.. I have ran 20 lbs. but Safely I like to keep it about 13-15. Yes stock engine, all of it. I also use the water/alcohol injection witch lowers intake charge temps. The alcohol makes up for the leaness that may happen with stock injectors pushing over 16 lbs. I only use the water/alcohol system over 15 lbs.
Old Mar 28, 2006 | 08:56 PM
1SIKZ's Avatar
Awesome.. I hope to pick one of these up soon (Greddy Profec B spec 2)
Old Apr 4, 2006 | 08:37 PM
c-murder's Avatar
I have one and it works great...It really holds the boost right where you want!
Old Apr 5, 2006 | 02:03 PM
1SIKZ's Avatar
murder.. apporximately how long does it take to install and do i have to buy amything else to install it or does it come with everything you need?
Old Apr 6, 2006 | 06:19 PM
Mousier158's Avatar
the kit dosent come with near enough vaccum hose. deffinately buy more hose! you'll need some "T" connectors to tap into existing vaccum lines. how many and what lengthof hose is dependant on how you plan to route the unit.
Old Apr 6, 2006 | 06:27 PM
1SIKZ's Avatar
quick question.. where exactly do i tap this into. and do i need to do it twice or?? on a twin turbo setup like the Z im confused as to how you would go about doing that
Old Apr 6, 2006 | 06:59 PM
Mousier158's Avatar
I forgot to mention you also need to buy hose caps size 4mm and 6mm.
Esentially you are bypassing the stock boost selenoids. you have to tap into the waste gate hose, intake hose, and fuel pressure regulator hose (remember everything x2). As i was saying before, it really depends what set up you want and how you are routing the lines. In the kit there's an instruction manual that will give you the generic idea, but because we are TT'd it's a little more difficult...less straight forward on set-up. Hope this helps.
Old Apr 6, 2006 | 07:03 PM
1SIKZ's Avatar
HAHAHAH you got any picture when you installed yours or do you know where a good write up is.. thanks
Old Apr 6, 2006 | 07:31 PM
Mousier158's Avatar
here's from the instruction manual. one from the way i routed it. see the "T" at the rear of the engine. that is where i brought the lines from the waste gate to one line that routes to selenoid actuator. then the "T" on the fuel pressure line which goes to the unit in the cockpit.
Attached Thumbnails ProFec B spec 2 settings-camera-408.jpg   ProFec B spec 2 settings-cimg0799.jpg
Old Apr 11, 2006 | 02:30 PM
Shameless's Avatar
Im in the same boat im working on installing mine right now and im slightly confused on how its actually supposed to work with our set up.
I already went and purchased more vacuum line but im confused on how the setup actually is supposed to go together. The kit comes with one Y connector would it be possible to run both vaccum lines from the actuator's to the y and then one line into the controller. LOL that diagram they give doesnt help us very much.
Hold on lol let me see if im understanding this better.
I have to run a hose from both of the actuator's run them into a Y or T and then one line into Which side of the Controller (no or com)
I also have to run a hose from each of the Turbo's compresser side pipes going to the intercoolers. I have to plug them into a T or a Y and then run them into one side of the Controller (no or com)
And i also have to run the smaller hose from the Cooled pipes leaving the intercooler and run them into a T or Y and then into the Unit inside the car?
My brain hurts.......
Old May 19, 2006 | 06:43 PM
1SIKZ's Avatar
HERE IS HOW I INSTALLED IT!!.. LOOKS SIK EH
Sorry i had to resize the pics like crazy to get them up here
