Problems that occurred in ONE day!
Old Sep 18, 2006 | 12:48 PM
MarkieMark's Avatar
And the Funky Bunch...wtf?
Well I was on my way to my friends party. On the way my check engine light
came on. Then the last turn to his block my hicas light goes on and power-
steering was not functioning properly. I was driving normal too. Mayn am I
pissed! And also my speedometer stopped working. Rpm,fuel, etc work.
So when all this happend I took the z home parked it back in the garage. I
checked the fluids and everything was normal. No leaks under the car.
I know there could be a ton of problems that causes the check engine light to
go on. What can I do for the hicas light? What should I check? Know what I
can do to fix the speedometer problem?
Old Sep 18, 2006 | 12:55 PM
Alternator???
Old Sep 18, 2006 | 02:17 PM
Riz Z Speed's Avatar
Administrative Brown Guy
for the check engine light, run the ECU codes and go from there.
Old Sep 18, 2006 | 03:13 PM
emo236's Avatar
confuzed member
2nd...run the ECU codes. It could be something as simple as a relay or fuse that went bad.
Old Sep 19, 2006 | 03:16 PM
MarkieMark's Avatar
trouble code 14.
something wrong with the speed sensor.
where is the speed sensor exactly located?
did a lil reasearch and a few others had experienced the same problems.
Old Sep 19, 2006 | 06:05 PM
silvrhand's Avatar
Snazzy Title
Should be two wires on the right side of your tranny, that's the speed sensor if memory serves me correctly.
Originally Posted by MarkieMark
trouble code 14.
Old Sep 19, 2006 | 08:19 PM
MarkieMark's Avatar
thanks!
i'll check that out on the weekend.
ZBspires
Aug 30, 2013 07:33 AM
86z31
Aug 16, 2010 06:14 PM
turbo84z
Jan 21, 2008 02:26 PM
duowing
Sep 30, 2006 08:26 AM
hondahunter
Mar 18, 2003 02:45 AM
