Passenger Window Off Track...
Any quick solutions? The window like gets stuck when its up. then falls down if the motor is in down position, and works if the window is halfway up/down. Just wondering how much does this cost to fix? Or maybe there is a "quick fix", Thanks guys..
its probbaly ur regulator that is bad. i had to replace mine cause it was bending on its way up. OR it could be those plastic clips that hold ur window glass to ur regulator that might hv lost its adhesive capabilties. open ur door panel up and diagnose. u'll figure it out.
ps: if the clips r broken ur pretty screwed. nobody sells em individually. u might hv to call around and get them from a junkyard. good luck.
https://www.zdriver.com/forum/showthread.php?t=12519 check this thread out. might help you.
hey, i def think ITS THOSE CLIPS. EVERYONE is saying it is. The window goes up and down fine wen its at half mas all the way untill about 3 inches from the top(im guessing where parts of the window hit the weather stripping keeping the window shhrugged.)
So does anyone know the ACTUAL name to this part? i know a junkyard with my car on the lift so they probabbly will have it. Just gotta know what its called.
Thanks alot!
Thanks alot!
