| dvlhntr13 |
Apr 16, 2004 12:57 AM |
Overheating TT: Electric fan or headgasket?
Ok my stock fan clutch went out on my manual 93TT (64K miles), A few weeks before I had the 60K mile service done by the local dealership. Well I knew something was wrong when my car lost a lot of power and sounded like a jet when I let off the gas. I was at my parents for the weekend and had a friend who is a mechanic (whom I trust a lot) look at it and said, replace OEM fan clutch, or convert to an electric. Well I went back to school/my home and thought about it. I went the electric route (bad idea….). had the local performance shop put in an electric fan. Well I got my car back and I drove it like a grandma for a bit. Then when I did not see it overheating I got on it, and well the temp started to come up. Well Now I have a car that is fine when driving normal but will begin to overheat under load. I checked the coolant it was a little low (halfway down the stick). I checked the oil, seems to be OVERFULL!!. I looked at the dip stick for signs of fouling. Did not see any. BUT THE DAMN THING IS OVER FULL. So here is what I am thinking. I got ripped off by local shop, should always stick with doing work yourself, or by people you have known for a long time. They might have just put in a fan that is just to small. I was told by a very nice and helpful guy at Z1 that this is not uncommon. Props go out to them for helping me even though I am in CO and they are in GA. I should go put the stock one back on and replace the fan clutch with OEM (have been told that aftermarket ones don’t work properly). I might have a weeping headgasket. I dread this like none other but the oil is overfull, and when I change it I am sure that with my luck I will see coolant mixed in with my mobil 1. Anyways could anyone who has done either an electric fan conversion or replaced a head gasket on TT please respond to me and give me ideas.
The only thing faster than my car seems to be it’s ability to deplete my bank account.
