OMG- Damn Plenum
Old May 27, 2005 | 01:34 PM
Seraphic's Avatar
Loves The Asian Chicks
OMG- Damn Plenum
being the last resort to fix my idle and power loss, went to take off the upper plenum to get to the injectors. and damn, its been a bitch. started around 10 this morning, currently 4, it feels like its ready to come off, but something is keeping it and i have no idea what. the front of it lifts up fine, but dead center in the back feels tight, ive searched around to see what it is, but i have no clue. i took some various shots to see if you guys can help me locate the problem. and yes, this my first real physical work on doing anything with the Z in the engine, i hooked up my exhaust, but this plenum stuff is a nuisance. please help. ive also referred to the TT-tech tut, but still cant seem to locate the problem.
EDIT [ evil problems while trying to get plenum off ]
Old May 27, 2005 | 01:58 PM
ZXDude90's Avatar
Aqua Teen Hunger Force Fan
Someone else might be able to tell you but this also might help. http://www.twinturbo.net/ttnettech/plenum/plenum.aspx
Did you try plugging that AIV hose and see if that helped?
Old May 27, 2005 | 02:13 PM
Seraphic's Avatar
yea, i plugged it.
Old May 27, 2005 | 02:44 PM
ZXDude90's Avatar
Crap, I need to pay attention to the damn post. You have already read that tech. Working night shift now is messing with my brain 91zxtt can probably tell you what it is, having just done it.
Old May 27, 2005 | 05:47 PM
Seraphic's Avatar
yay!!! i got it off.
only problem is, is now the the screws to the seals of the injectors feel like theyre heated shut
Old May 27, 2005 | 05:58 PM
ZXDude90's Avatar
Glad you got it off. I can't view the photos though. It says bandwidth exceeded.
Old May 27, 2005 | 06:37 PM
Seraphic's Avatar
ZX- Fixed. whats a good spray that'll clean off connector corrosion, luckily i didnt break any. theyre just full of grime
Old May 27, 2005 | 06:41 PM
Riz Z Speed's Avatar
Administrative Brown Guy
go to the local auto parts store, they should have a corrosion remover that you can spray on there.
Usually it's reserved for battery terminals but if they're that bad then you could use it on the connectors.
since you got the plenum off, now would be a good time to clean the hell out of it and make it shine real nice like.
Old May 27, 2005 | 06:49 PM
Seraphic's Avatar
oh i plan to, probably going to end up getting colored hoses and a polished plenum
Old May 27, 2005 | 07:09 PM
b300z's Avatar
caught the z fever
dang dude you showed that plenum what was up
but yea...make it shine
Old May 27, 2005 | 08:19 PM
Denver93TT's Avatar
So what was the final culprit? From the pics it looked like your EGR tubes were still connected. With the EGR bypass the plenum is about 35min to take off and 45 to put on. Yeah, dude make it shine shine shine.
Old May 27, 2005 | 09:19 PM
Seraphic's Avatar
not sure the of the names for it, but theyre were to hidden hoses in the back under the wiring harness. can you explain to me this EGR bypass, sounds extremely helpful
82zxturbo
Nov 23, 2007 10:48 AM
hoov100
Oct 11, 2006 09:49 PM
NismoPick
Nov 14, 2005 07:53 AM
oldschool
Apr 14, 2005 11:24 AM
CrazyLotusTT
Sep 27, 2002 12:57 AM
