oil pressure due to the oil pan having a dent???
Old Sep 11, 2007 | 11:33 AM
RichardZ32's Avatar
Can this happen my friend is looking to buy a Z, and I was told by the guy that the car is not getting any pressure due to a dent in the oil pan. I would think the sending unit has gone out any info?
Old Sep 11, 2007 | 12:24 PM
entropy31's Avatar
The Cake Is A Lie!
i really doubt the dent is the cause. the sending units tend to be a common cause of "no oil pressure". but how big is the dent, and what caused it?
Old Sep 11, 2007 | 11:44 PM
ViperGTO99's Avatar
I agree, I doubt the dent is causing it... I'm only giving the following advice based on NON-Z experience, but if it helps, then great!
Find the pressure sending unit. (I personally don't know where it is... just look around for it, or check with someone that does know), disconnect the electrical connection and look at the plug... if there's oil on the inside of the plug, at the contacts, the sending unit had a little 'blow-out' and needs replaced.
Good Luck.
Old Sep 12, 2007 | 09:10 PM
91zxtt's Avatar
I agree....it's likely the sending unit; however, there is very little clearance between the oil pick up and the oil pan...a dent in the right (or technically wrong) place can be a problem.
Old Sep 15, 2007 | 06:55 PM
KasbeKZ's Avatar
Pr0n Addict
i havn't seen the exact layout of the underside of that engine, but a lot of them have the oil pump right in the bottom of the sump. if there is a big dent in the lowest part, it could actually have mashed up into the pump. maybe even have bent the pick up tube
quidproquo
Northeast Region
May 5, 2010 10:57 AM
KasbeKZ
Sep 21, 2007 08:21 PM
flightforlife07
Dec 10, 2006 08:35 AM
inqui-Z-tor
West Region
Nov 11, 2006 01:22 PM
81 Black L28E
May 22, 2005 03:04 AM
