Oil level gauge na to TT
Ok, I just had my N/A Z onverted to a TT and 5spd. My oil gauge keeps reading on the low side but when i check it,its fine whats up with that.
it's an oil pressure gauge. not oil level.
you mean your oil pressure gauge?
check the sensor...it is by the oil filter |
gshl
My fault... I meant to say that :) ..I'll have that sensor checked, But it still reads low, should i be concerned? or stop driving it?
If your oil level or pressure is low, you'll know it............ it won't sound right. It should be a concern, but I would suspect the sending unit too. Am aftermarket gage kit is alway better.
The oil pressure sending unit is a very common problem.
| All times are GMT -7. The time now is 03:12 AM. |
