new to the z32 had a few questions about my recent engine drop
so lets start at the beganing im on ebay one day looking for another honda to build when i come across a beautiful 1990 tt 300zx i always liked how they looked twin turbo 2 seater with ttops just a dream so the guys asking 3600 for it or so i click on it had a missfire in 2 cylinders on the left bank ok no big deal has a new harness new injectors new coils and its really clean end up buying the car for 2800 bucks drove down to maryland that weeked put her on trailer and brought her home so i tore the motor all down since everything was out of the car already and put all new sensors seals gaskets cleaned everything up so the motor got dropped in this weekend got everything hooked up on but she wont start just turns and turns well the car sat since 2007 so i figure its gas so i sprayed some start fluid to see if she would sputter nuthing at all i have spark so idk whats going and the timings good to
welll there is one plug right by the firewall thats hooked into the harness but i cant find anything on the motor anywhere im gonna get a picture of it and put it on here tommorrow to see what you guys think i just wna get her running and drive here |
Make sure you are getting fuel pressure to the fuel rails, make sure the ECU is working and is not fried, if it is working see if it's throwing a code, make sure the CAS is plugged in all the way and the wiring is not corroded, make sure you do not have a gross vacuum leak/s and make sure you did the cam timing right. Also make sure you are running the OEM NGK's.
