ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   Need Help!!-Fuel coming out of the intake (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/need-help-fuel-coming-out-intake-36966/)
Robert_A727 Jan 30, 2013 03:57 PM
So I was working on my 300zx and one of the injector o-rings were bad, so I had to remove the whole intake plenum. Got all new seals for the fuel rail and fuel injector and put everything back together(All the right ways too). I turn it on and it ran for a little bit but fuel was coming out the exhaust then it shuts off and I try to turn it back on again and then I noticed fuel was leaking under the car and turns out the fuel was coming from the intake and it was only the passenger side leaking fuel from the intake.
I have absolutely no clue what it could be. All line and connections are in the right place cause I know that for a fact. Please someone help!! Most stressful thing right now for me.
GODDAAMMMBATMAN Jan 30, 2013 07:09 PM
Check the fuel rail and the connections from the fuel rail to the diaphragms above it. Make sure everything is tight.
Robert_A727 Jan 31, 2013 05:30 AM
What diaphram are you talking about?
