Motor Update Action
Old May 26, 2010 | 07:46 PM
domsgarage's Avatar
Tough Guy
Motor Update Action
Took the Z out tonight for its maiden voyage.
Feels really good. Feels a lot tighter then the other motor, no leaks, its not burning anything. Feels good.
I think theres still a slight miss somewhere that I have to look into, theres a backfire a little bit but after I took it out that cleared it up. Im also running about 1/3 of a can of seafoam with probably only about a gallon of gas so that was making it lean and smokey but so far so good.
Im definitely happy i went with the swap instead of pouring money into other issues.
As far as the other motor went, I pulled off the timing cover and noticed there was absolutely no tension on the lower intake pulley, so the belt was reasonably loose, im assuming thats the issue. The cams are all rusted up and the water pump / thermostat area are pretty corroded and rusted up. The swap was the right thing to do.
NismoPick
Oct 28, 2024 08:34 PM
SheAngel19
Aug 25, 2013 01:50 PM
hoov100
Sep 17, 2007 10:20 PM
91Zman
Jun 5, 2006 10:03 PM
Spudz
Jun 4, 2003 10:41 PM
