More Big Problems with the Z
Old Nov 29, 2004 | 01:21 PM
MetalTear17's Avatar
Well, I am really getting tired of all these problems w/ my Z, it is absolutly rediculious that everytime I fix somthing another thing majorly goes wrong. Now I Have perhaps the wierdest thing happening. Start the car, everything seems to be ok, rev it up alittle and everything (a/c controls etc.) goes out except the backlighting of the instrument cluster, which progressivly gets brighter the higher reving the engine. Radio still works fine, headlights fine etc.... O and my oil pressure is REALLY high and my dip stick shows over full, wierd because I just changed my oil with the exact amount of oil needed. Any ideas? I'm trying my best not to get any more fed up with this car.
Old Nov 29, 2004 | 03:24 PM
91zxtt's Avatar
Sounds like you have a short in the elctrical system. Check your grounds. As far the oil pressure goes, it could be a sending unit. Find the short 1st. If that doesn't fix the reading on the oil pressure gauge, then change your sending unit.
Old Nov 29, 2004 | 05:32 PM
CanyonCarver's Avatar
Jack Of All Trades
You might also try getting the alternator checked first. Although it might be producing electricity, the regulator might be bad.
It does sound like a short.............
ZBspires
Aug 30, 2013 07:33 AM
86z31
Aug 16, 2010 06:14 PM
turbo84z
Jan 21, 2008 02:26 PM
duowing
Sep 30, 2006 08:26 AM
hondahunter
Mar 18, 2003 02:45 AM
