Mas
Mas
I recently bought a dual air induction kit. obviously i will get my computer tuned for it, however my question is should i run two Mass Air Flow sensors or just the stock one? and if I do run a second one does anyone know how i would go about wiring it in? can splice of the stock one or do i have to run separate lines? Thanks.
You only use the 1 MAF, but you need to install a 2nd 'blank' MAF. It's just a dummy unit. The reprogrammed ECU is designed to meter approx. 1/2 of the original airflow. Where did you buy this unit? It should have come with the necessary hardware & software upgrades.
Run a VG30DETT MAF, or Q45 (VH45DE) MAF. There is no EASY way to integrate a second MAF. ECU/M would have to be completely remapped.
Hit up some junk yards, ask about like a 1991 Q45, they should have one you can break apart.
Just a thought. Most of my boss's project cars have Q45 MAF's, he said the kick it adds is amazing.
91zxtt, as with any upgrade to powertrain, if is always more effective to have the ECU/M remapped. But Im almost 100% sure that it is plug and play. My boss use's the Q45 MAF on his RB engines (Skyline engines). Im going to give it a try when I get my new Z. But if the Q45 MAF DOESNT work, I promise the TT MAF will, i've seen this done on many Z's.
That's my guess. I didn't realize there was a difference between the NA and the TT MAF. The Q45 MAF would probably be able to meter more air. The TT MAF can meter enough air for about 450-500HP. After that, you need to convert over to the Twin intake setup.
