Its gotta be something obvious...
OK, All I did was put in new spark plugs and a cone filter. One of the coils broke, so i replaced it. Now when I start it, it acts like it is choking to death, and promptly dies.
WTF?
I have triple checked to make sure everything is connected as it was previous to me loosening the first bolt, so it isn't that. All the plugs are tight, but not too tight. The gaps on the plugs are all good.
I have to be missing something obvious, but I'll be darned if I know what.
Help!
Thanks!
WTF?
Help!
Thanks!
do a search...i think we had something similare to this and had to do with the cone filter...some crap...i might be wrong and just thinking bad. if zlover makes it on here he might just throw you the answer.
Thanks! Problem solved. I was doing the job alone and trying to listen from the driver's seat. As soon as my roomate came home and i was able to stick my head under the hood (i needed him to keep the rpms up so it would stay alove long enough for me to listen) i found it.
Like i said, somethig obvious. I inadvertantly bolted a bracket under the tube that covers the last two coils.
When I did it, it was back before I worked for Ultimate Z. I think it was the first time I did spark plugs, and the bracket had fallen into place while I was doing it, so I didn't think to take it off again before putting the plenum back on.
