ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   idle issues/Stalls in neutral over 40-50 mph? (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/idle-issues-stalls-neutral-over-40-50-mph-33401/)
paulman592 Sep 3, 2011 11:21 AM
hey all,
I've had an issue with my Z for the past month or so, whenever I coast from a speed over 50 mph, the engine will stall out. I will crank the ignition with clutch in and it starts right back up, but something obviously isn't right.
Below 50mph, no stalling. Occasionally there will be problems with idling to high (idle @ 2000RPM) but it eventually corrects itself.
any ideas?
'93 300ZX Convertible, Manual
ZLover4Life Sep 4, 2011 08:10 AM
Your cone filter is improperly installed.
http://s95014253.onlinehome.us/63104/80397.html
xcom90 Jun 17, 2012 06:09 PM
i have stock everything and mines does the same thing. every post i keep reading is taking about fixing it if you have a aftermarket cone filter but i have stock everything and mine still does that any help? my is N/A also
SLE-PR Sep 15, 2012 01:28 PM
Same Problem??
Did anyone figure this engine stalling problem yet? I just picked up yet,,,, another '90 NA w/ 5 spd this time and this one is stalling too, when it is allowed to coast in neutral. It also wants to rev about 1500 rpm around town when pulling up to stop signs.............any ideas on that one???
Thanks, J.
Rupe Sep 17, 2012 04:13 PM
Check the cleanliness of your air filters?
