Ideling too high
Old May 27, 2005 | 12:35 PM
nka04a's Avatar
Ideling too high
Ok my car has been ideling at about 2,000 RPM. It only does it when iv been driving for a while. In the morning i start it up and it does fine idels at about 800 RPM after it gets warmed up. But then when I go some where at stop lights its at 1700-2000 RPM and some times it bounces around from 900-2000 RPM like its possesed or something. I just replaced the spark plugs with the OEM NGK's and i cheaked all the vaccume lines like 20 times already its not that i dont think. So if anyone has any ideas plz help me out. Im about to take it to the nissian dealer if I cant fix it my self. Thanks
Old May 27, 2005 | 01:05 PM
Riz Z Speed's Avatar
Administrative Brown Guy
do a little more searching here.
that too high idle seems to be quite the common problem lately, there's been several threads with the problem and solution.
Old May 30, 2005 | 01:12 PM
nka04a's Avatar
Thanks man. I figured out what the problem was. All I had to do wsa reset the ECU now it idels fine.
Old Jun 15, 2005 | 12:24 PM
Nycz Z32's Avatar
o word? cuz i had the same problem, and when i took it to the mechanic they told me that i needed to replace my EGR valve...haven't replaced it yet so i don't know if that's the problem
Old Jun 15, 2005 | 06:58 PM
91zxtt's Avatar
Hmmm...that's a new one. High idle caused by the EGR. I don't think so. Find a new mechanic.
Old Jun 29, 2005 | 11:05 PM
1ntegtype1's Avatar
there is a few things that you can actually do to lower your idling. I had the same problem as you did. Try it and see if it helps but becareful.
First there is an Idle Adjusting screw on the drivers side only visible if you go to the right fender looking straight to the other side. Its hard to see but if you can reconize the screw its actually very visble. By turning it you can actually lowers the rpm or raise depending which side you turn the screw.
Second there is the CAS ( crank angle sensor ) locacted in front of the engine on the drivers side. Its held by three 10mm screws loosen it (DONT REVOVE IT) but mark it so you'll know the original spot that it was in if it doenst work. Try rotating it and this will also lowers your idle rpm. ( Im pretty sure adjusting both what Iv'e just mention will work. BUT PUT THE CRANK ANGLE SENSOR BACK WHERE IT WAS IF IT DOENST) Let me know if it works.
Old Jun 30, 2005 | 07:19 AM
b300z's Avatar
caught the z fever
never do that first.
if you do that, you are just masking the problem
that is for fine tuning your idle when everything else is working correctly
Old Jun 30, 2005 | 07:56 PM
91zxtt's Avatar
^^^That's some of the worst advice I've ever read. Do you have any idea what turning the CAS actually does? It adjusts your timing. Never adjust your CAS without a timing light. You could cause serious damage to your engine. Don't give advice if you don't know what you're adjusting.
Like b300z said....adjusting the idle screw is merely masking the true problem. The idle scre is set from the factory and should really be sealed. There is a cause to the high idle and it's not the idle screw. Find the real problem instead of trying to half-*** the repair.
Old Jun 30, 2005 | 09:27 PM
1ntegtype1's Avatar
Ur right that does adjust the timing. I didnt say to retard the timing to the limit. That is why i also mention the precautions of doing it and here is another thing if you do it right you can hear the rmps drop. My experience with my Z when all this happend was running 15 miles per gallon. Now its running at 18 after all the small adjustments. But hey maybe its just my car. Don't take it too personally.
Old Jun 30, 2005 | 10:04 PM
bardabe's Avatar
Bad Speller
that would go to his 2nd signature.
Old Jul 1, 2005 | 05:41 AM
CanyonCarver's Avatar
Jack Of All Trades
Yep........ the timing has a nominal setting determined by the factory. You can only set the timing to the nominal setting with a timing light. Besides other problems being created with the timing being off, advancing it will increase idle speed and retarding it will decrease idle speed.
On any car, at any time, with any problem, you first need to start eliminating the variables, starting with a tune-up, ie: good plugs, clean filters, good fuel, etc.... then run ecu codes. If all is o.k. there, then you start the process of elimination.......... let's see, high idle, are the throttle / cc cables properly adjusted? Are the cables becoming frayed and sticking? Do you have any vaccum leaks? Has the iacv been cleaned? Are the injectors leaking? One it's determined that everything is in proper working order, and your idle is still high, you might then need to adjust the little screw.
82zxturbo
Nov 1, 2007 06:32 PM
hoov100
Feb 7, 2007 09:10 PM
justinmy300z
Feb 20, 2006 09:02 PM
reyazul
Sep 8, 2002 03:06 PM
nissan1990
May 7, 2002 09:33 AM
