I Have A Problem!!!
Old Oct 18, 2006 | 09:48 PM
ILoveMyFairlady's Avatar
I Have A Problem!!!
Ok, ok, yes, the first step is admitting it. LoL
Ok here's the skinny, My 1990 M/T N/A z32 fairlady dies after coming down from high rpm's.
If i ride like a good boy it's fine, but if i ride like a fat kid to the ice cream store, it hates me for some reason.
If i take off and shift at 3.5 rpm or more in each gear and push the clutch in or pull into neutral from 3rd, 4th, or 5th gear it will drop rpm to 2-3 hundred and die on me. I can rev up to save it but it's hard to brake for a light and rev up at the same time.
Old Oct 18, 2006 | 10:13 PM
Z Car Barbie's Avatar
User Friendly
Welcome! It would save a lot of time and guessing if you go ahead and check the ECU for trouble codes. Click HERE for the procedure.
Old Oct 19, 2006 | 12:52 AM
entropy31's Avatar
The Cake Is A Lie!
learn heel/toe. it's easy.
Old Oct 19, 2006 | 02:02 AM
js9krcr01040's Avatar
Sept Z of the month
Hahaha, heel/toe. Also check all your vacuum lines. Sounds like you might have a leak. A big leak.
Old Oct 19, 2006 | 08:24 AM
japanz's Avatar
What is the condition of your MAFS? And yes, run your codes.
Old Oct 19, 2006 | 08:29 AM
z-hag's Avatar
Queen of Yachts
heel /toe funnn---worse gets the problem, the more funner you'll find it--there are so many reasons why your car is doing that--i know-- my AE had ALL of 'em--but it is wonderfullll now
Old Oct 19, 2006 | 09:03 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
Do you happen to have a pop charger or other cone-style intake on this car?
In most instances where this happens, it's a combination of a cone style intake and the IACV being set too low.
Search though... I instructed someone on how to adjust their idle and resolve the cone-style intakes not 2 months ago.
Old Oct 19, 2006 | 03:28 PM
haha heel toe...soo easy....jsut learn to rev match while your at it...screw a clutch. and yeah...run codes, zlover is smart so reply if you have a intake like he said. he can throw up a write up on it or something. and if it was a vacumme leak wouldnt it hardly idle then to jsut after start up? not after letting off the gas? sounds almost like turbo cars when your boosting and just let off and it chokes it from teh mixture being to rich...but its not turbo, i just felt liek throwin that up there.
Old Oct 19, 2006 | 06:59 PM
emo236's Avatar
confuzed member
yea, I was gonna ask if you had a popcharger and not a splash shield. There's a duct tape trick if that's your problem, but I recommend just getting a new splash shield. Stalling after high revving with a popcharger is common. If not, an air leak or something electronic (run your codes like stated before).
Old Oct 19, 2006 | 08:00 PM
... sounds almost like turbo cars when your boosting and just let off and it chokes it from teh mixture being to rich...but its not turbo, i just felt liek throwin that up there.
This only happens with turbocharged cars that have blow off valves (not recirculation valves, which come on the Z32), and can be resolved via Apex-i AFC II (it has a setting where you can lean out the mixture when the RPMs drop, thus eliminating the rich condition from venting metered air).
By the way, all you people saying "heel-toe"... that's a bandaid fix. A healthy car should be able to resist stalling when coming down from speed. Sh*t, if your car wouldn't idle, would you just keep your foot on the accelerator or would you get it fixed? My philosophy... resolve the problem or buy a car that is more reliable. Bypassing the problem is for poor people... poor people should not be driving a 300ZX - they aren't exactly cheap to maintain.
Old Oct 19, 2006 | 08:06 PM
entropy31's Avatar
The Cake Is A Lie!
did you really think i was serious about that?
Old Oct 19, 2006 | 08:49 PM
I didn't think so, but with the way some others responded to it I got the impression that some people would encourage that. Not to mention, if the thread starter thought you were serious, he may simply think that's the solution (and considering the way the Z32 community seems to be going, what with people wanting to swap in 4 cylinders, I'd rather take the initiative to protect the sanctity of the Z than hope that the owner knows better... my faith in the everall community has diminished over the years).
I hope you didn't take offense to it though.
Old Oct 20, 2006 | 12:16 AM
haha 4 cylinders...and yeah i forgot it was with BOV's....i knew...but fogot...had no clue the afc could do that though thats cool and very nifty......ill remember that if i ever make it around to gettin me a turbo car... i want car....
Old Oct 22, 2006 | 07:46 PM
Two new symptoms
It now smells bad of gas when i stomp it. and if a cruise in any gear and only press the peddle a little it jumps and stalls like its choking for air or fuel.
My boss sais that that's a common symptom of a bad fuel pressure regulator and im inclined to agree with him seeing as my old z32 had the same problem and a tech pinned it down to that.
Old Oct 22, 2006 | 07:51 PM
nismo619's Avatar
RUN CODES !! WWW.TTZD.COm can help u out more then we can.. " eaze out on the clutch ? " aka ride the clutch "
Old Oct 22, 2006 | 07:55 PM
But.. Wait.. I don't.. Huh?!?
Im not throwing a check engine light so will that help anything?
Old Oct 22, 2006 | 09:57 PM
emo236's Avatar
confuzed member
You and your boss may be right. It may be fuel related. the fpr is a possibility. I'd check that by hooking up a fuel pressure gauge into your fuel system before the fuel filter, of course.
Myzsucksass
Nov 28, 2013 06:58 AM
turbo84z
Oct 10, 2006 07:30 AM
HybridS130
Sep 2, 2006 05:50 PM
pearly whites
Oct 30, 2003 01:37 PM
saaddaa7
Oct 24, 2003 08:19 PM
