How much for tuneup (tires)
Guest
Posts: n/a
For those who have done this how much should it cost. My car gave me an estimate but I think its a bit high. I just bought a 91 2+2 but it has about 115,000 miles on it and I'm not sure when or if it has been serviced.
By the way anyone also know of good but affordable tires for it. Since I am in Wash DC most of the time I am looking for good ride comfort over handing. Need an all season tire though.
Thanks ahead of time for the good advice.
well a tune up for a Z32 is easy. Just check/change plugs and check timing. Since the Z32 has no distributor cap and no plug wires, it's a snap.
Since you just bought your Z, do you know if the 60K maintanence was done? Your about due for another. Basically the 60k is a tune up with a timing belt, fuel filter, air filter, and oil change.
http://www.courtesyparts.com/z32/z32-tbkita3.html
Here's a site that should give you a good idea what the parts'll go for. The labor on the other hand is a different story. The timing belt is not easy but if you feel up to it, here's how to do it.
http://www.ttzd.com/tech/60ktech.html
