Hicas/Abs light on!!!
Old Nov 10, 2005 | 07:22 PM
oldschool's Avatar
This morning my Hicas light turned on and I was slighty loosing power steering. I was going around 65mph when it happend. My Abs light turned on also when I hit the brake hard. When I got home I check the Hicas fluid resevoir and it was full. I turned off the car and turned it back on. Eeverything went back to normal power steering and Abs light never came back on. What can I do to fix this problem!!!!
P.S. I have a 1990 300ZXTT
Old Nov 10, 2005 | 08:34 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
How's your speedometer working? Since the HICAS is speed sensative, a bad speed sensor could cause a condition like that if it's occuring at a certain speed (that's the cause in my case).
I'd say it could be a bad HICAS system, but in my entirely Z life (and in my entire career at Ultimate Z) I only ever even heard of 1 HICAS system failing and it was on a 96.
do this
http://www.ttzd.com/tech/hicastech.html
Old Nov 10, 2005 | 09:24 PM
oldschool's Avatar
The Hicas ligt started to come on after the ABS light came on. When I got home from a 45 min. drive I turned off the car and turn it back on the system is back to normal again. The power steering is working properly.
Old Nov 10, 2005 | 09:52 PM
if it's in conjunction with the ABS light, I know EXACTLY what it is... it's a fuse.
http://www.twinturbo.net/net/viewmsg...&msg_id=950732
Old Nov 11, 2005 | 06:04 PM
oldschool's Avatar
Thanks man!!
Dirt Winston
Mar 26, 2013 08:26 AM
joel280zt
Aug 2, 2012 06:10 AM
Rupe
Dec 4, 2011 11:28 AM
ricky0288
May 27, 2011 10:07 PM
300zxBoi
May 7, 2003 11:04 PM
