Hesitation problems on my 93 zx.
Guest
Posts: n/a
My 93 300zx n/turbo 5 speed hesitates or stalls, It does it only once or twice every time i drive it, but the accelaration drops dramaticly even when I'm stepping on it, until I let go and shift it. Please any help would be appreciated.
Guest
Posts: n/a
Re: Hesitation problems on my 93 zx.
Could be a few things, but here is what I would look at first.
If the engine is stalling only when its extremely hot, then you might be suffering from "vapor lock", but since you didn't mention any overheating I'll assume its doing this at normal engine temperature.
If its stalling and hesitating at normal engine temp I would check the fuel pressure regulator, your engine is likely starved for fuel.
Hope that helps,
Adam
1996 300Z TT
Hope that helps,
Adam
1996 300Z TT
