Help temperature and gas gauge stuck
So I was fixing the odometer and it is working. For some reason when I installed the back the temperature
immediately goes to hot even the car is clearly cold and stays like that. In addition the fuel gauge went to 1/4 when I had 1/2 a tank left. As I’ve been driving it the fuel has been going down so I guess it isn’t calibrated correctly I’m not sure. I tried some things like checking the connectors to see if I accidentally put them on wrong, but they are fine. I have no idea what the problem could be and I could really use the help if anyone has experienced this before when putting the dashboard back on to the Z32.
